Need help!!! - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 19 Old 02-23-2020, 01:09 PM
Quoted: 143 Post(s)
I tired studying the wire diagram . its an impossible to really trace where the wires go . it does not help the book splits the diagram on to two different pages .
cataway is offline
post #12 of 19 Old 02-23-2020, 08:06 PM
Quoted: 143 Post(s)
well...……...…......ya could all ways run a hot wire to the coil , i'd put a switch of some kind in the line
cataway is offline
post #13 of 19 Old 02-24-2020, 11:53 PM
JPP
JPP's Avatar
Quoted: 8 Post(s)
I’m thinking of a fault on the starter motor
JPP is offline
post #14 of 19 Old 02-26-2020, 11:19 AM
Quoted: 143 Post(s)
be nice to hear back from Dylan700xx
cataway is offline
post #15 of 19 Old 03-02-2020, 10:10 AM Thread Starter
Sorry for the late reply... no i don’t believe it’s related to the starter. As stated it turns over extremely well. Compression out the exhaust and such. Just no spark. I’m about 99% confident it’s the stator/crank sensor and replace the coil as well. So gonna give that a shot. Found a decent deal on a used one, seems to be hard to find a stator for these?? I’ll report back when parts come in.
Dylan700xx is offline
post #16 of 19 Old 03-03-2020, 10:04 PM Thread Starter
Reporting back guys, GOOOD NEWS!! Done alittle more digging and decided to pull the stator cover off once more, noticed the cranksensor/pickup had some markings/scratches on it??! So with that being said I figured it wasn’t close enough to the fly wheel, so I ground down the centering notches on the sensor bracket, and drilled the holes a couple sizes bigger, which aloud me to adjust the sensor, got it where I wanted, through it all back together, and wouldn’t you know it, she fired right up, no issues!! Sad thing is new stator should be here soon, so may keep it as a spare or send it back.. probably not a permanent fix, or the best one, but it was free and now working properly. Just really not sure how those marks got on the sensor to cause it to be to far from the flywheel and not to create a signal.. but anyways hope this helps someone in the future. And thanks to all who replied!
post #17 of 19 Old 03-04-2020, 06:16 AM
Quoted: 255 Post(s)
Glad you got it fiqured out! And thanks for posting the results.
M_Quick is online now
post #18 of 19 Old Today, 07:25 AM
are wires hooked to the coil ?
opgo01 is offline
post #19 of 19 Old Today, 02:12 PM
Footy's Avatar
Quoted: 45 Post(s)
Wow, good wrenching right there!
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
