Electrical issues after riding steep drop off - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 02-24-2020, 07:45 PM Thread Starter
Question Electrical issues after riding steep drop off
Yesterday I went down a 6' straight down drop off. Immediately the quad started missing and running like crap. I figured the angle sensor had "tripped". So I shut the key off, restarted the bike but it seems to have gone into a limp mode. At this point, I disconnected the battery right on the trail hoping things would reset. That didn't work had to limp it back about 4 miles to trailer. It quit several times but restarted every time, did not rev over approx 1/8 throttle. Got it home and it would not start at all. All dash lights are blinking and sometimes will go out and leave the neutral light just dim. I left the battery unhooked overnight and went back and hooked it up today and still have the same problem. When turning the key on the engine stop relay clicks over and over and the dash lights blink along with it. While playing with the key switch and on off switch today I managed to get the neutral light to somehow come on bright and heard the fuel pump "charge up" and the bike started. I let it idle for about 4 minutes and it died on its own. Played with the 2 switches again and after a few minutes got it to start again. I touch the throttle and it dies. Anybody have any idea where to start diagnosing this problem. I have the Honda service manual, no luck there. I purchased the bike new and has no mods. Thanks for any help.
karl2017! is offline
post #2 of 3 Old 02-24-2020, 09:08 PM
Quoted: 144 Post(s)
near the front sprocket there is a censer .has a wire plugged into it . if that comes unplugged it will run crappy . that my first guess
cataway is offline
post #3 of 3 Old 02-26-2020, 05:57 AM
Footy's Avatar
Quoted: 47 Post(s)
I would also check the battery voltage. Almost sounds like the drop off might have caused a plate inside the battery to fail.
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
