Trx700 - Page 2 - Club700XX - Honda TRX700XX Forum
 1Likes
post #11 of 16 Old 03-14-2020, 10:12 PM Thread Starter
Am thinking from the coolant system
LAKERS
mike700xx2008 is offline
post #12 of 16 Old 03-15-2020, 06:50 AM
Footy's Avatar
Quoted: 46 Post(s)
Please understand that I am not an engine builder by any means but I would guess that you either have a head gasket problem or a water pump seal issue.
If your water pump seal is worn out than that is fairly direct. However if your head gasket is the problem then that is most likely a symptom of something else.
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #13 of 16 Old 03-19-2020, 12:39 PM
Quoted: 144 Post(s)
apparently there is no rebuild kit for the XX coolant pump ? seems odd to me . service book does show rebuilding it
cataway is offline
post #14 of 16 Old 03-19-2020, 01:01 PM
Quoted: 144 Post(s)
if coolant was getting past the maniacal seal of the coolant pump it would be flowing out of the weep hole hose
cataway is offline
post #15 of 16 Old 03-25-2020, 11:10 PM Thread Starter
Almost sound like its head Gasket problem... 🙄unfortunate.. so will see have to probablly tear it open
LAKERS
post #16 of 16 Old 03-26-2020, 11:10 AM
Originally Posted by Kubi07 View Post
You can also check to see if your thermostat is working.
agree
jacinda is online now
