Ok guys so i recently purchased another xx , ( used) with a bunch of goodies, changed the oil , flushed the coolant cleaned out the air box, etc... & then resulted the bike had a fuel problem took it to the shop & they cleaned out the fuel system , cleaned the injector& changed my fuel peetcock lever, old fuel.. etc.. & now my Oil seems to be liquidfy like if some how there is water in the oil tank or coolant. Not sure what happend there bike does fire up but after 10 minutes of idle temperature light comes on ... ( fan does not come on) & today it did the same thing , it also started to leak coolant from above the radiator , all this was not happening before... i took it to the shop,
** not sure if this has anything to do with it ... but i did see them add more coolant which was some kind i never seen before,(basically 2 kinds of coolant) in it....
Not sure what i should do next besides drain ( oil & change filter???) Input & feedback greatly appreciated)đź’Żđź’ˇ
