swamped - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 04-21-2010, 12:00 AM Thread Starter
hairtrigger0299's Avatar
mad swamped
Apparently I'm the only idiot to swamp my 700xx as I have searched and read until my eye balls were ready to fallout. After being out done by a 400ex in the mud pit I realized it was likely the 350lb difference and the air box setup isn't exactly ideal for such things. We pumped it out and I've changed the oil 5 times however now I have a knock that sounds like its on top the motor with or without load but more prominent when warmed up and taking off. I just pulled it apart to check the screens. there was a little crap on the tank screen but nothing on the crank screen(big pain in the a$$) I've also noticed that the oil level is inconsistent sometimes low and sometimes over full. This is why I assumed the screen was an issue and the crank oil level plug was over full. I am currently reassembling but will attempt to record the sound. I don't believe I have a bent rod or valve as it still makes great power but i just don't know what it could be (yes my oilf ilter is on correct). Thanks for any help you may have.
hairtrigger0299 is offline
post #2 of 12 Old 04-21-2010, 07:29 AM Thread Starter
i have also checked the valve clearences
post #3 of 12 Old 04-21-2010, 07:57 AM
Tory trx's Avatar
If the oil levels are inconsistent I would have guessed a clogged oil screen. Have you changed the filter with all oil changes? If not I would again. Maybe drain everything and just dump some cheap oil right through the bike and let it drain directly out. Maybe catch anything that's left. Good luck and let us know how it goes.
Tory trx is offline
post #4 of 12 Old 04-21-2010, 09:15 AM
The oil tank is pretty straight forward to remove without any technical steps to worry about. I've pulled mine already and filled it with gas, shook it around, drained and reinstalled. While it's off you can pour some oil or diesel through the valve cover to wash the motor. If you use diesel I usually chase it with a little oil after it drains to dilute any standing diesel that may stay on the motor. Doing this is after submerging the quad is better than changing the oil and running it repeatedly.
post #5 of 12 Old 04-21-2010, 09:59 AM
post #6 of 12 Old 04-21-2010, 10:36 AM
TRX_Sixpac_700xx's Avatar
I swamped mine damn good last summer, but mine was well passed just a little knock because I got a ton of sand through the motor. Surprisingly my quad ran quite well after all of it though. I started out way too optimistic and tried cleaning it out myself by flushing the oil and so after draining as much of the sand out as possible I started her up and she actually sat in idle very nicely. There was no knock or anything like you have.
Well, I'm not sure about your knock, but I just wanted to let you know that you aren't the only idiot. Good luck with yours!
TRX700XX
-UNI Air Filter
-2Bros Exhaust
-2 Bros Juice Box
-13T Sprocket
-Pro Armor Fat Pegs (Black)
TRX_Sixpac_700xx is offline
post #7 of 12 Old 04-21-2010, 10:41 AM
post #8 of 12 Old 04-21-2010, 10:49 AM
knock knock
Who's there?
TRX700XX
-UNI Air Filter
-2Bros Exhaust
-2 Bros Juice Box
-13T Sprocket
post #9 of 12 Old 04-21-2010, 11:00 AM
Originally Posted by TRX_Sixpac_700xx View Post
Who's there?
Rod....
post #10 of 12 Old 04-21-2010, 12:41 PM
knock could be a bent rod as water cannot compress.
Agrees with Scuzz can also be a broke piston skirt or numerous other things doesn't sound like getting enough oil is the problem but definantly got some serious issues with it I don't know if warranty will cover it check with your dealer.
silliestdaddy is offline
