08 trx700xx wont stay running - Club700XX - Honda TRX700XX Forum
 1Likes
post #1 of 11 Old 04-29-2020, 01:37 PM Thread Starter
Hello, new to forum. Got a 08 that is stock. Ran like a bat out of he'll for the weekend. Brought it out few days later and while riding I experienced loss of power, but of back fire and it died. Let it sit for a minute amd it started up and idled fine. As soon as I started to give it some gas and release the clutch an it died. Changed oil and oil filter. Flushed coolant and gas and am currently waiting on a fuel filter conversion kit to come in. In the mean time, I have run it (resting lifted on atv jack) on 5 occasions and each time it sputter and dies at the 10 minute mark. Anyone know what might be causing this?
JJTrx700xx is offline
post #2 of 11 Old 04-29-2020, 06:48 PM
Spark plug.
Sent from my iPad using Tapatalk
post #3 of 11 Old 04-29-2020, 08:29 PM
Footy's Avatar
Quoted: 47 Post(s)
Is the fuel tank vent hose stock or one of those aluminum bling bling type? Is it plugged up?
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #4 of 11 Old 04-29-2020, 08:46 PM
Quoted: 144 Post(s)
had the gas cap not venting on a different quad . it happens
cataway is offline
post #5 of 11 Old 04-30-2020, 01:46 PM
Yeah vapor lock sounds like a good idea, I missed the part about quad dying after 10 min run time. That's also about how much fuel the pump holds, so also check fuel lever.
Vig likes this.
post #6 of 11 Old 05-18-2020, 02:15 PM
I'm having the same issue. Not the gas cap, checked that. Runs great 15-20 mins then a couple of small backfires then dies. Let it sit 15-20 mins and it'll run, then die.
sarcher is offline
post #7 of 11 Old 05-18-2020, 05:51 PM
How long does it run the 2nd time?
post #8 of 11 Old 05-25-2020, 12:50 PM
My 700xx won't stay running unless I put gas in the air box
Kacee Jo Pruitt is offline
post #9 of 11 Old 05-25-2020, 12:52 PM
I was also having that problem. Then my stator bolt came loose and messed up the whole stator got a new one but now it won't stay running unless I pour gas in to the air box
post #10 of 11 Old 06-03-2020, 03:17 PM
Did you get it up and running. I'm having a similar issue and think it's fuel related.
Donnie Kunkel is offline
