Overheating exhaust causes - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 09-06-2020, 11:08 AM Thread Starter
Quoted: 4 Post(s)
I recently acquired a 09' 700, the quad has been neglected and poorly stored, it has its original tires that have nearly full depth tread.so this quad I believe has low hours, My problem is that in the past it evidently has had a overheating problem, I will post pictures and invite your suggestions on what to look for. I will have to replace the rear fender, rear
master cylinder cover, air filter box and rear exhaust heat shield. I drove it around the block in my neighborhood and the
heat generated from the exhaust pipe on my inner rt. leg seemed excessive. What could be causing this?
zedrone is offline
post #2 of 4 Old 09-12-2020, 11:51 PM Thread Starter
Quoted: 4 Post(s)
Bump
zedrone is offline
post #3 of 4 Old 09-13-2020, 09:29 AM
The exhaust could be corked up?
M_Quick is online now
post #4 of 4 Old 09-13-2020, 03:42 PM Thread Starter
Quoted: 4 Post(s)
I did find a Mud dobber nest in the spark arrestor! It wasn't fully blocking the exhaust but probably enough to cause the problem
zedrone is offline
