Settings on the EHS Programmer... - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 04-24-2010, 09:03 PM Thread Starter
Has anyone played around with the settings on your EHS progarmmer, if so what were the best?
I have the Barker Exhaust, EHS progarmmer/lid and I'm running the recommended settings, but occassionally it backfires through the carb and shuts off. It starts back up fine, but I wonder if I'm a little rich or lean? I have a Hot Cams stage 3 cam coming, if it ever gets here and I can't decide on a 11:1 or 12:1 piston. I still want to run pump gas, but I'm not sure if the 12:1 will work. Any thoughts?
Thanks for your input,
Bryan
chandlerrb is offline
post #2 of 15 Old 04-24-2010, 09:56 PM
USMC0861's Avatar
11:1 way safer on pump gas....the recomended settings are working fine for me. If your way up in alt. you might have to take a little fuel away...otherwise you should be good. (way up in alt, try taking a half point off each of your first three settings.)
USMC0861 is offline
post #3 of 15 Old 04-25-2010, 06:05 AM
It wouldn't be wise to run 12:1 on pump
post #4 of 15 Old 04-25-2010, 05:43 PM
b.courtney_700xx's Avatar
dissapointed in you smooth1 thought for sure youd jump on the backfire thru the carb comment, clearly it is a efi machine. your slippin buddy, not good for your run at moderator
2008 trx700xx
dg steel series nerf bars
13t renthal
3D powertip
razrs on her feet
b.courtney_700xx is offline
post #5 of 15 Old 04-25-2010, 06:21 PM
I took my valium today, I'll make up for it tomorrow.
post #6 of 15 Old 04-25-2010, 06:56 PM
eclipsegs0's Avatar
i was gonna mention sumthing about the hole back firing thru the carb but wasnt 100% sure if he was talking bout the 700
08 trx700xx
ehs programmer
eclipsegs0 is offline
post #7 of 15 Old 04-26-2010, 09:47 PM
Bryan
Ok besided the carb deal explain the problem a little more because im sure its not back firing through the TB unless something is drastically wrong like cam timing, valves, or nos.
are you running QC as well?
EHSRACING is offline
post #8 of 15 Old 04-28-2010, 03:39 AM Thread Starter
Occasionally when letting off the throttle and getting back on it, the quad backfires through the “TB” and shuts off. This usually happens after a couple of hard laps when I'm relaxing/putting around. It's kinda like it is loading up at the lower RPM's and when I nail the throttle after putting this is when it happens. I did drop the bottom settings in .5 increments twice and it still did the same thing. The quad is stock at the moment other than the big three. I do have the quiet core insert installed, but wouldn’t think that would make a difference with the recommended settings for the controller. I really need to just find the time to have you dyno the quad for me. I think I will wait until I put the cam and piston in before I come see you. I live in Goldsboro, so it’s not that far of a drive.
b.courtney/eclipsegsO, Carb or TB, fairly similar and I would think the Barker exhaust/programmer would give it away. (typo or word usage, take your pick)
Others, thanks for the responses
post #9 of 15 Old 04-28-2010, 07:54 AM
Try lowering the green blue setting from 3.5 to a 1.5 to see if it helps if it does you may need to play with that mode. You could have a TPS sensor that is slightly outta wack this will disguise it some or it could just need more fuel earlier. By lowering the green blue you will tell the green circuit to come on sooner creating a richer condition earlier so if you are to rich like you think you may actually need to do the opposite but i would guess your feeling a lean stumble not a backfire if its a backfire i would be more ap to guess it was something else wrong. When you let off the throttle you are pretty much cutting out almost all pulse to the injector so are controller will actually stop adding and fuel by lowering the GB setting it will turn off just a split second later allowing the fuel to carry better when you get back into the throttle.
Let me know im sure we can get you squared up without having to come get on the dyno. But you are more than welcome to come over anytime
post #10 of 15 Old 04-28-2010, 07:57 AM
Also with the QC try to lower first 3 to
Green 3
Yellow 3
Red 2.5
