In need of some advice!! - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 04-25-2010, 08:19 PM Thread Starter
Ok this weekend was the first time i had my xx out in the wilderness, it was raining like hell and i had to prove the xx could go places where the 4x4s can go . went through some water about up to the top of the tires and hit some pretty deep puddles at pretty high speeds. anything that needs to be checked?
2008 black/gray xx
2006 Silverado 2500hd 6 inch Fabtech suspension lift
"God is great, Beer is good, people are crazy" Billy Currington
bdbub7 is offline
post #2 of 8 Old 04-25-2010, 08:27 PM
Check your box. If your box is not stuffed then your good. If it is, rinse and repeat.
post #3 of 8 Old 04-25-2010, 08:51 PM Thread Starter
By box you mean airbox correct ?
2008 black/gray xx
bdbub7 is offline
post #4 of 8 Old 04-25-2010, 09:05 PM
Yeah! that's the main thing that can get water in and cause damages, if you look under the air box on the left side in front of the rear wheel you'll see a plastic tube about 1.5" long with a clamp, remove the tube and if there's any water in the air box, it will drain from there.
post #5 of 8 Old 04-25-2010, 09:19 PM Thread Starter
ok Thanks will check that soon
2008 black/gray xx
bdbub7 is offline
post #6 of 8 Old 04-25-2010, 09:58 PM
Also, check your filter if there is water in there, if it is wet, take it off and let it dry out/clean it if it is dirty first/ and then get some filter spray like PJ1 (any foam filter spray will work though). Also, a good idea if you're riding in the wet/ or after washing, blow it off w/ air if you can, so you don't have sitting water, especially around where the spark plug is.
post #7 of 8 Old 04-25-2010, 10:51 PM
TRX_Sixpac_700xx's Avatar
I do this after every ride anyway, but I would be sure to oil your chain.
TRX700XX
-UNI Air Filter
-2Bros Exhaust
-2 Bros Juice Box
-13T Sprocket
-Pro Armor Fat Pegs (Black)
TRX_Sixpac_700xx is offline
post #8 of 8 Old 04-26-2010, 08:33 AM
Tory trx's Avatar
Anytime I ride in lots of mud or water, I double check almost every component on the bike. Like adjusting the emergency brake, air filter and box, tires, headlights and fluids including topping of the tank. I am a bit over the top but it makes me feel better knowing that the bike is all ready for the next ride. Just start it jump on and go.
Tory trx is offline
