i need some honest answers - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 04-28-2010, 10:58 AM Thread Starter
aubfans's Avatar
I'm straddling the fence on whether or not I should take the plunge and get the big three. I'm interested in purchasing; a controller, a full exhaust, and modifying my air box lid.
If I do these upgrades and my riding style dosent change *other than the increased power* How much will the lifespan/reliability of my 700 suffer , as a pose to keeping it stock?
"Pretty good, is hard to beat."
aubfans is offline
post #2 of 16 Old 04-28-2010, 11:03 AM
gavineli's Avatar
Alltho i dont have the big 3 on my honda i did put it on my 97 banshee and it is still going strong today only thing needed to be done to it is the norm top end rebuild cause of being 2 stroke i would say go for it
gavineli is offline
post #3 of 16 Old 04-28-2010, 11:04 AM
Reliability should not be effected at all as you have not changed the internals of the motor.
post #4 of 16 Old 04-28-2010, 11:11 AM
Adding the Big3 will not alter the longevity of the quad.
post #5 of 16 Old 04-28-2010, 11:37 AM
TRX_Sixpac_700xx's Avatar
I agree with everyone else, but I'll add that if you don't have your EFI controller set up correctly it could shorten the life of the engine, but you have plenty of help on here to make sure that that will not be a problem.
TRX700XX
-UNI Air Filter
-2Bros Exhaust
-2 Bros Juice Box
-13T Sprocket
-Pro Armor Fat Pegs (Black)
TRX_Sixpac_700xx is offline
post #6 of 16 Old 04-28-2010, 12:25 PM
Tory trx's Avatar
The only way I can see the Big3 hurting the engine is if you get so obsessed with the power that you end up beating on the bike. But, then again if you keep it stock and need more power, you might end up beating on it anyway. The main reason mine is mostly stock is because of the money issues. Also I am just fine with the power it has now. I don't really race and for the trails I hit mostly, it is just fine. But......if I had the money I would probably do it.
Tory trx is offline
post #7 of 16 Old 04-28-2010, 03:02 PM
in a sense the big 3 is actually makeing the engine run more efficient you are opening it up allowing it to breath better with exhaust and intake and are makeing it run the optimal fuel curve with the controler. which in turn also add a little bet of get up and go to it as well
post #8 of 16 Old 04-28-2010, 04:48 PM
Absolutely agree!
2006 Raptor 700
post #9 of 16 Old 04-28-2010, 06:51 PM Thread Starter
aubfans's Avatar
if the big 3 make the 700 engine more efficient wouldn't Honda install this at the factory before the machine was ever sold?
more efficient & longer lasting = more attractive product = higher sales
aubfans is offline
post #10 of 16 Old 04-28-2010, 06:55 PM
Emissions & Cost
