Best oil for desert riding, hot days? - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 05-04-2010, 05:38 AM Thread Starter
markas214's Avatar
I live near Phoenix and it will be getting hot very soon. I want to ride as long as I can into the summer. 100 degree days would still be tolerable for me but I'm concerned about my motor. I plan on going full synthetic my next oil change. Price is not a consideration. I use K&N oil filters and currently have Castrol Evol Xtra semi synthetic oil. I read about a few synthetics including Honda HP4S. That only comes in 10w30 though. Suggestions?
Renthal 13 tooth sprocket
Alba Pro Elite nerf bars
CCP steering damper
L8ton Racing 9/16 Swaybar
Teixeira upper a-arms
Powermadd handguards
markas214 is offline
post #2 of 19 Old 05-04-2010, 07:34 AM
https://www.club700xx.com/vb/showthread.php?t=3605 ???
post #3 of 19 Old 05-04-2010, 08:11 AM Thread Starter
markas214's Avatar
Originally Posted by smo0oth1 View Post
Your point being what, that I can't ask a vendor a question and submit the same question to the general forum? Besides that, how many people do you suppose look in the vendor area compared to this area? Also while Amsoil has great products I'd like to learn what experience people had with other synthetics. Understand?
CCP steering damper
post #4 of 19 Old 05-04-2010, 08:56 AM
My point was questioning multiple post. Yes you may submit the same question many times. I'm not sure of how many people look at the vendor section but maybe we could setup a pole to find out. My experience with synthetics is that I can't tell wtf the difference is from brand to brand. They all look the same to me going in and coming out. I read up on it allot but come to find out most of the articles are sponsored by one of the brands.... Go figure. What I don't understand is the size of your signature. :-P
Full synthetic would be ideal since your not worried about price. The decision of what grade to to use is debatable. My opinion. Start with 10-30 on new motors since tolerances are still close and enables better lubrication. Once the motor is fully broke in you could go to 10-40 if desired. I'd like to believe closer grade oils like 10-30 protect better than the larger spread viscosity's due to there being more lubricant and less modifiers per quart. But that's just my uneducated opinion also. Another thing to consider is since our rockers are non roller an oil with higher ZDPP levels would be nice. But then again you wouldn't want to use the "high mileage" oils due to them having chemical to swell seals... With all these things to consider it's mind boggling and now understand why you posted multiple times. As baxter would say... Cheers! :-)
post #5 of 19 Old 05-04-2010, 12:01 PM
skier207's Avatar
Check out these threads, lots of discussion about oil. I like the Shell Rotella synthentic.
https://www.club700xx.com/vb/showthread.php?t=396
https://www.club700xx.com/vb/showthread.php?t=2679
skier207 is offline
post #6 of 19 Old 05-04-2010, 10:39 PM Thread Starter
markas214's Avatar
... Cheers! :-)
and you signature? Anyway thanks for the input.
CCP steering damper
post #7 of 19 Old 05-04-2010, 11:42 PM
I read a thread that full synthetic wasnt good for the xx because it causes clutch slippage. Unless its made for motorcycles I believe.
08 700xx The FASTEST X INFINITY gray/black
08 800 Polaris rzr heavy modded $$$
PLZS SAVE THE WORLD BRING BACK 2 STROKES
CHAINSAW372 is offline
post #8 of 19 Old 05-05-2010, 01:03 AM Thread Starter
markas214's Avatar
You need to avoid synthetics with molly. Otherwise I know you can run it. I'm leaning towards Amsoil.
CCP steering damper
post #9 of 19 Old 05-05-2010, 05:08 AM
09RappySE's Avatar
Quoted: 16 Post(s)
Want to know the difference between oils? do your own testing and you will know.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #10 of 19 Old 05-05-2010, 07:01 AM Thread Starter
markas214's Avatar
Wow why didn't I think of that? So much easier than asking a simple question on an internet forum.
CCP steering damper
