How can I make the stock exhaust less restrictive? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 05-05-2010, 10:59 PM Thread Starter
How can I make the stock exhaust less restrictive? I don't want to buy another exhaust.
Is it possible to take the spark arrestor off. If so could someone explain it.
2008 700xx x 6
yes 6
Front: RAZR 2 - 22", Rear: RAZR 22x10x11
Uni Air Filter
Coming: FMF efi, full exhaust, Skip plates, bumper
2009 Rubicon 500 x 2 - Mudlites
2008 XR650L x 2 - full-exhaust, lowering kit
2006 Raptor 700R - exhaust, bumpers, skip plates, Swamplites on rear
2008 CRF450X (Sold) - full-exhaust
2008 TRX400EX (Sold) - bumpers, skip plates
2006 TRX350 4x4 (Sold) - Bear Claws
Golden-Boy is offline
post #2 of 7 Old 05-05-2010, 11:20 PM
Yeah you could take the 3 bolts out and pull the spark arrestor out then take a holesaw and cut threw the first baffle. I took my sparky out the other day and it made the xx sound like crap plus it didnt run as good so it seemed. If you took a holesaw to it you would probby want a fuel programmer though because it may run lean. If you holesaw it you can then put the spark arrestor back in "too cut the sound some" or you can even cut the arrestor pipe and screen off and just put the end cap back on to work as a quite core end cap. Hope you understand what I'm sayin lol.
I have done several different exhausts this way in the past with good results along with rejetting the carb and a more open intake.
08 700xx The FASTEST X INFINITY gray/black
08 800 Polaris rzr heavy modded $$$
PLZS SAVE THE WORLD BRING BACK 2 STROKES
CHAINSAW372 is offline
post #3 of 7 Old 05-05-2010, 11:33 PM Thread Starter
thanks, I already have the FMF efi controller and uni air filter. I'll try it out thanks.
2008 700xx x 6
yes 6
Uni Air Filter
post #4 of 7 Old 05-06-2010, 12:26 AM
you can order a 3d power tip just opens her up a little and its a shiny piece!!
post #5 of 7 Old 05-06-2010, 06:55 AM
Tory trx's Avatar
I did the same thing here is the thread.https://www.club700xx.com/vb/showthre...exhaust+baffle
Tory trx is offline
post #6 of 7 Old 05-06-2010, 10:31 AM
Yep, it does sound a little better and is within legal sound limits. But that's about it... no power gain. It is better than stock however... and it's shiny... roadkill like shiny things.
post #7 of 7 Old 05-10-2010, 07:02 PM
You could take it off. Throw it away, and call EHS and get a Barker put on. But that would be a little more costly
2008 700xx Barker Full, EHS Lid, EHS box, Uni Filter, 13T sprocket, DS450 shock swap, Pro Taper Contour Bars, Spider Grips, Front: ITP Baja's & Razr 2's, Rear: ITP9's & Razr 2's
jwherndo is offline
