Heads up !!! Head pipe shield - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 05-05-2010, 11:28 PM Thread Starter
I gotta new xx and just wanted to let people know that you better take the allen bolts out of the head pipe heat shield and put loctite on them then snugg'em good. I have about 10 hours on my xx and all the bolts were coming out of the heat shield yesterday.
08 700xx The FASTEST X INFINITY gray/black
08 800 Polaris rzr heavy modded $$$
PLZS SAVE THE WORLD BRING BACK 2 STROKES
CHAINSAW372 is offline
post #2 of 12 Old 05-05-2010, 11:33 PM
BigDog's Avatar
Good advice, I'll check mine tomorrow. I had similar problems with a generator I bought last year. I let it run for 4 hours straight, went out and ther were literally bolts laying on the ground all around.
2008 TRX 700XX
FMF 4.1 Factory Full System
UNI Air Filter
Renthal 13T Front Sprocket
BigDog is offline
post #3 of 12 Old 05-06-2010, 02:47 AM
i had the same problem with mine when i got it
aussie700xx is offline
post #4 of 12 Old 05-06-2010, 11:03 AM
kms15's Avatar
i already lost one,three days after i put a slip on exhaust on they vibrated out. definitly use lock-tite
kms15 is offline
post #5 of 12 Old 05-06-2010, 11:56 AM
Originally Posted by kms15 View Post
i already lost one
Same here. :(
The rest have stayed on though.
post #6 of 12 Old 05-06-2010, 02:49 PM
eclipsegs0's Avatar
i lost the whole heatshield during a race sunday lol
08 trx700xx
ehs programmer
eclipsegs0 is offline
post #7 of 12 Old 05-14-2010, 11:04 AM
Xstriker's Avatar
lol that sucks. I lost a bolt out of mine the first week I had it. I replaced the exhaust now though so it doesn't really matter.
08 TRX 700XX
HMF Full Performance Exhaust
EHS Programmer
11/16 L8ton Swaybar
Skat~Trak Haulers 20X10X10
Alba Pro Elite Nerfs
Trail Tech Vapor Speedo/odom
Xstriker is offline
post #8 of 12 Old 05-17-2010, 10:12 PM
atleastitsnotaford's Avatar
A good salesman at the dealership should have told you to check them after the first few rides as they will come loose. Usually just once retightening them keeps them in there. This is common for any vehicle, on any bolt on the exhaust (namely the ones holding it to the head) and on lug nuts, check those too.
Two of mine came loose after the first ride, half turn tighter, and no more problems.
atleastitsnotaford is offline
post #9 of 12 Old 05-19-2010, 02:41 PM
TRX700XXX's Avatar
I had the same problem and lost the middle one.
TRX700XXX is offline
post #10 of 12 Old 05-19-2010, 07:32 PM
XXed's Avatar
Me too! Where can we get replacements bolts?
XXed is offline
