Oil analysis - Club700XX - Honda TRX700XX Forum
post #1 of 47 Old 05-09-2010, 09:12 AM Thread Starter
09RappySE's Avatar
Quoted: 16 Post(s)
Oil analysis
For those of you who want to know how much dirt a K&N filter lets by and how much of a difference the foam wrap makes on you K&N filter...here you go...take a look at silicon levels before and after, it drastically dropped silicon (dirt) to a level I can deal with in the sample and in turn all wear metals dropped significantly as well, the high lead is from a couple tanks of race gas. So for all you guys that think a K&N filters well here is the proof. Just thought I would share it with you guys.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #2 of 47 Old 05-10-2010, 11:20 AM
I'm only phone and having trouble comparing. How did you perform these tests? What's the variables?
post #3 of 47 Old 05-10-2010, 08:44 PM Thread Starter
09RappySE's Avatar
Quoted: 16 Post(s)
Samples were taken at oil change and sent to blackstone for spectrometric analysis, although I am not sure where the center colum numbers are from the far right are universal averages, the first colum is my most recent sample with 6 hrs on the oil with the foam wrap, the third colum is 12hrs on the oil with just the K&N no foam wrap.
734 09 Raptor
post #4 of 47 Old 05-10-2010, 11:06 PM
Whats a foam wrap on a k&n ?
08 700xx The FASTEST X INFINITY gray/black
08 800 Polaris rzr heavy modded $$$
PLZS SAVE THE WORLD BRING BACK 2 STROKES
CHAINSAW372 is offline
post #5 of 47 Old 05-10-2010, 11:20 PM
Chainsaw: It's a type of outterwear. (prefilter)
Rappy, What type of terrain are you riding?
post #6 of 47 Old 05-11-2010, 04:50 AM Thread Starter
09RappySE's Avatar
Quoted: 16 Post(s)
I ride in dusty/sandy areas.
734 09 Raptor
post #7 of 47 Old 05-11-2010, 12:58 PM
scrawny's Avatar
ive never had luck with K&N, always failed the "wipe inside the intake tube" test with a finger full of dirt/dust.
uni foam stock style filters have always done the best for me.
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
post #8 of 47 Old 05-11-2010, 02:52 PM
mytrx700xx's Avatar
why not just use a UNI filter?
mytrx700xx is offline
post #9 of 47 Old 05-11-2010, 11:48 PM
I no what a prefilter is but its not foam . Is there a prefilter made outta foam ? Is he just talkin about a regular k&n prefilter ? I've never seen the foam one.
post #10 of 47 Old 05-12-2010, 04:25 AM
It is a regular K&N prefilter is all, like the black mesh. There would be no point of running a foam w/ the K&N, I actually don't think it is possible.
