Intake Lid - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 12-15-2008, 02:41 AM Thread Starter
Intake Lid
Im reading a lot of people taking off the air intake lid on their Hondas. I get the benefits, but what are the drawbacks to this? Does this increase the likelihood of dirt in the engine? etc.
SWiSS916 is offline
post #2 of 8 Old 12-15-2008, 05:11 AM
If you run with no lid at all, you will be changing or cleaning your filter before a whole day of riding. Especially in dusty areas. No lid does flow more air, but you need to increase fuel to get the full benefit from it, like with a Power Commander. I went with these guys. They modify a lid, complete with filter material, ready to bolt on. This cover is almost waterproof and keeps the inside of the airbox much cleaner. WWW.EHSracing.com
Dave01 is offline
post #3 of 8 Old 12-15-2008, 08:12 PM
I bought an EHS cover as well. Nice product with the benefit of an open box and with that Outerwear top it keeps stuff out.
Cowboy is offline
post #4 of 8 Old 12-16-2008, 02:12 AM
Dave,
did they just cut out a square and use the outerwears material to cover up the whole? What kind of filter do you have? Whats the bottom of that lid look like?
post #5 of 8 Old 12-16-2008, 02:33 AM
Originally Posted by 5W0P3 View Post
Dave,
I am running the Velocity filter set-up. Here is a link to some good pics of the lid. The only change i made to mine once i got it was to seal a little around the aluminum frame that holds the Outerwear material on. Its 100 percent waterproof now
http://www.ehsracing.com/products/tr...airbox_EHS.htm
Dave01 is offline
post #6 of 8 Old 12-16-2008, 02:34 AM
I've been looking at that... I'd think it'd be pretty easy to make, no?
post #7 of 8 Old 12-16-2008, 02:50 AM
I would think so too. I went wwith thiers because I didnt know what size to cut the opening or anything like that. Now that I have one, it sems like an easy mod, other than the snorkle block-off plate. I would just make an Outerwears cover for that too
Dave01 is offline
post #8 of 8 Old 12-16-2008, 02:52 AM
Either that or "Great Stuff!" would probably work well. I'd think this would work well if you happen to sink your quad. I know its not water poof, but if its water resistant it might at least not suck any water through the snorkel.
