Throttle Question...Please help...Thx - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 05-14-2010, 08:15 PM Thread Starter
kygoat's Avatar
I've noticed that no matter how still I try to keep the throttle in one place the engine will still change rpm. Just slightly back and fourth. Is this normal?
'05 Wolverine
kygoat is offline
post #2 of 11 Old 05-14-2010, 09:09 PM
The TB butterfly is driven by wire so it would be odd to have it fluctuate normally. Check the basics, Plug, plug wire and fuel. I'd say it's mind or finger playing tricks on you.
post #3 of 11 Old 05-15-2010, 09:23 PM
BigDog's Avatar
You might need to change your throttle filter.
2008 TRX 700XX
FMF 4.1 Factory Full System
UNI Air Filter
Renthal 13T Front Sprocket
BigDog is offline
post #4 of 11 Old 05-16-2010, 10:47 AM Thread Starter
kygoat's Avatar
Really? This problem is annoying. I also notice at low speed, real jerky.
'05 Wolverine
kygoat is offline
post #5 of 11 Old 05-16-2010, 02:36 PM
BigDog's Avatar
kygoat -- I was just kidding, kind of like muffler bearings.
Take it in to the dealer, if it's still under warranty they should fix it.
2008 TRX 700XX
UNI Air Filter
BigDog is offline
post #6 of 11 Old 05-16-2010, 03:05 PM
kygoat,
I can only assume you are riding the machine while all this is going on. Well, I gotta tell you; I have a devil of a time maintaining a perfect throttle/thumb position while I am riding on rough surfaces. Hill up hills down, rutted areas, I'm not sure there is something wrong with your machine. But I could be wrong.
post #7 of 11 Old 05-16-2010, 04:48 PM
The jerky feel is normal with the XX at low speeds. It honestly sounds like there is not a problem, The motor will fluctuate with the most minute movement of the throttle.
post #8 of 11 Old 05-18-2010, 06:10 PM Thread Starter
kygoat's Avatar
Feel better about now. Just seems odd still. Thx all...
'05 Wolverine
kygoat is offline
post #9 of 11 Old 05-19-2010, 09:13 AM
Tory trx's Avatar
In my line of work we ask the green horns to fetch the board stretcher or 7 or 9 penny nails.
Tory trx is offline
post #10 of 11 Old 05-19-2010, 09:57 AM
HAHA, when I was on the boat, I would have the new guys fill out their I. D. TEN. TENGO form, saying it was for safety reasons, and they wouldn't read it, (something I had made all up)...pretty much says I am hereby certified an IDIOT LOL.
