Not a good start - Club700XX - Honda TRX700XX Forum
post #1 of 26 Old 05-16-2010, 05:53 PM Thread Starter
pissed Not a good start
Guess I will be getting the pipe sooner than planned. Really Sucks the Search wont work right now..
I replaced my Ching Ching quad with this one to avoid these types of issues, but it still happened to the 700...
I broke 2 easyouts and 3 drill bits and still managed to destroy it... Oh well..
Universal_Diver is offline
post #2 of 26 Old 05-16-2010, 06:02 PM Thread Starter
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
Anyone want it? 30$ shipped. I cant use it anymore.
The EHS Big Three package is very very tempting.....
post #3 of 26 Old 05-16-2010, 11:10 PM
blkcruzer's Avatar
I have the stock exhaust with the 3D Aluminum tip if you are looking to just replace that on the cheap, let me know if you are interested.
2008 TRX700XX Black/Red
Mods:
Trail Tech Vapor with Riser
ODI Rogue Grips
Pro Armour FatPeg Nerfs
PRM rear grab bar
PRM .190 full skid plate
Pro Design K&N Intake
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
DS450 front reservoir shocks
L8ton 11/16 Sway bar
blkcruzer is offline
post #4 of 26 Old 05-17-2010, 12:10 AM
Everything is turning into Ching Chings nowadays. You cant have anything good anymore.
08 700xx The FASTEST X INFINITY gray/black
08 800 Polaris rzr heavy modded $$$
PLZS SAVE THE WORLD BRING BACK 2 STROKES
CHAINSAW372 is offline
post #5 of 26 Old 05-17-2010, 07:16 AM
Just turn the tip to where the bolt holes are in the middle of the old holes and drill and tap them. Put new bolts in and you don't need a new muffler. Wel, that is unless you "need" a new muffler.
My buddies 400ex did that and that is how he fixed it.
post #6 of 26 Old 05-17-2010, 09:19 AM
Can you reach it from inside to silicone a nut and washer to the backside?
post #7 of 26 Old 05-17-2010, 12:30 PM Thread Starter
Yep I can get jb weld or epoxy nut and washer, and I may well try that, I wish I could figure a way to get it tight enough if I rotated it and used new holes. That metal is tissue thin. plus where the welded nut tore out it ripped enough metal that it is very close to the side. so as in the picture.. I would need to Bootie fab something to plug the hole.. I really dont want to do that. I think I am talking myself into at the minumum a slip on.
Then I guess a programmer.
I called EHS and they are closed till the 20th.
post #8 of 26 Old 05-17-2010, 02:46 PM
droby1242's Avatar
try to plug the holes (jb weld) and use blind rivets with high temp sealant. wet seal the rivets in this should help with exhaust leaks. this should help as a temp reapair to hold you over untill you get a new exhaust. if you need hardware let me know.
droby1242 is offline
post #9 of 26 Old 05-17-2010, 02:56 PM
just run it without what the cap.... lol
post #10 of 26 Old 05-18-2010, 12:09 AM
droby1242's Avatar
I agree
