How often do you change your oil??? - Club700XX - Honda TRX700XX Forum
post #1 of 47 Old 05-17-2010, 10:44 PM Thread Starter
Just wanna know how often everyone does this
2008 black/gray xx
2006 Silverado 2500hd 6 inch Fabtech suspension lift
"God is great, Beer is good, people are crazy" Billy Currington
bdbub7 is offline
post #2 of 47 Old 05-17-2010, 10:50 PM
i did mine at the first 20hr then at 100hr next in gona do it at 200hr or when the oil gose black. no need to change it every 10, 20, 30 hours like some ppl do thats just a waste of time and money i cand spend riden.
post #3 of 47 Old 05-18-2010, 06:21 AM
If I race mine, then every 2 races as I am usually in the HIGH RPMs for most of the race. If I am just leisure riding, every 20-30 hours. Some people want to wait until the 100hr mark, but it is cheaper to buy oil and filters than it is to replace something.
post #4 of 47 Old 05-18-2010, 07:13 AM
It all depends on the type of riding I did, if it's real dusty and slow going then I'll change it more often.
post #5 of 47 Old 05-18-2010, 07:27 AM
700ATP's Avatar
Yep, that slow going is the key....if your fan has to kick on alot to keep engine cool, then you want to cut your change interval in half....that heat will break the oil down fast
08 700xx....Turkey Bay Rider....
700ATP is offline
post #6 of 47 Old 05-18-2010, 08:41 AM
09RappySE's Avatar
Quoted: 16 Post(s)
I change mine at 10hrs max, and there is a very good reason to change it often, I guarantee you your oil breaks down long before you will hit 30+ hrs. it is cheap insurance for a high cost investment that I want to last...but to each his/her own.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #7 of 47 Old 05-18-2010, 09:12 AM
Prograde Oil's Avatar
Well I am working on something right now to make sure you guys will benefit from using an oil analysis. What this is going to do is give you an inside look at the way your engine is working with your oil. It will give you particle counts on dirt and metal fragments and fuel contamination as well. It will even give drain interval reccomendations. I am going to post a thread about it in a couple of days. Basicaly though, you will no longer have to GUESS on wether the oil is still good or not so that you can get everything out of each oil change!
Take care
Prograde Oil is offline
post #8 of 47 Old 05-18-2010, 10:03 AM
Xstriker's Avatar
ditto... why risk causing engine damage when you can just change the oil a little early. Generally I'm every 4-5 rides (couple hours each usually)
08 TRX 700XX
HMF Full Performance Exhaust
EHS Programmer
11/16 L8ton Swaybar
Skat~Trak Haulers 20X10X10
Alba Pro Elite Nerfs
Trail Tech Vapor Speedo/odom
Xstriker is offline
post #9 of 47 Old 05-18-2010, 11:38 AM
I don't change my oil on a set schedule. Everything depends on what kind of riding I've been doing.
post #10 of 47 Old 05-18-2010, 12:26 PM
skier207's Avatar
Same here
skier207 is offline
