carb tuning help??? - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 05-19-2010, 01:12 PM Thread Starter
carb tuning help???
i know its a little out of our efi world but i need some help with my teryx. got the right jets in but how do i tune out a lean miss when i let out of the throttle? i know a lot of you have had carb bikes before. it only pops after getting on it and then letting off, oh and its dual carbs. thanks
post #2 of 16 Old 05-19-2010, 01:26 PM
blkcruzer's Avatar
I believe from the snowmobile days that raising the clip on the needles is what would fix that.
Jason
2008 TRX700XX Black/Red
Mods:
Trail Tech Vapor with Riser
ODI Rogue Grips
Pro Armour FatPeg Nerfs
PRM rear grab bar
PRM .190 full skid plate
Pro Design K&N Intake
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
DS450 front reservoir shocks
L8ton 11/16 Sway bar
blkcruzer is offline
post #3 of 16 Old 05-19-2010, 02:04 PM
You're correct, usually I would put the clip in the center position then go riding and see how it felt at all throttle position then I would check the plug and if need be, I would adjust the clip either 1 notch up or down depending on the throttle response and plug. Don't forget to ride the bike at high rpm then shut it down then check the plug.
post #4 of 16 Old 05-19-2010, 02:05 PM
here's a good link;
http://atv.off-road.com/atv/article/....jsp?id=190926
post #5 of 16 Old 05-19-2010, 02:39 PM
But I thought main jets are used when at WOT, needles in the middle and pilot on low???
2006 Raptor 700
post #6 of 16 Old 05-19-2010, 02:44 PM
Hell! I don't remember, lol!! That's why I posted the link, they know allot more than I do.
post #7 of 16 Old 05-19-2010, 02:45 PM Thread Starter
ok i think im gonna try the neddle tonight i just really dont want to dyno thats a nother 200 buck i know its close. now moving the needle down fatten it up and moving it up leans it out right?
post #8 of 16 Old 05-19-2010, 02:57 PM
Here's a great link about this
http://4wheeldrive.about.com/gi/dyna...s/jetting.html
post #9 of 16 Old 05-19-2010, 03:38 PM Thread Starter
thanks that was a good link. this will be the 4th time ive tore this thing down. damn carbs and wanting to go fast. lol
post #10 of 16 Old 05-19-2010, 04:45 PM
put bigger pilots if they are the same as the brute force you will need 40-size 74 series. Im about positive they are i have them in stock if you need. they also dont have adjustable needels you need to shim them unless you install different needles like DJ
EHSRACING is offline
