how to snorkel XX? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 05-23-2010, 09:37 AM Thread Starter
alt1031's Avatar
how to snorkel XX?
I know I should just buy a ute, but I like the challenge. Does anyone know how and what to use to make this work? I took my xx out in thru some real deep places with no problem, i just want the added protection.
alt1031 is offline
post #2 of 6 Old 05-23-2010, 09:51 AM
The only viable way would be to remove the air box and run PVC out towards the back. Secure connections would be really important or you would risk sucking in more water with the snorkel than without it.
post #3 of 6 Old 05-23-2010, 01:50 PM
Smooth is right. Out the back, probably tap right into the throttle house, use that same diameter all the way back. You could possibly use some rubber tubing instead of PVC, like what you could get on a truck intake. I don't know where you could get it though. But that would be the only way to do it, unless you were to cut a hole in the seat. You're filter would have to go on the end of it. The only other way would be to cut a hold in the back of the air box, and run PVC out from there, but you would need to get another cover that is definately air tight.
post #4 of 6 Old 06-04-2010, 05:33 AM
double_0_xx's Avatar
I would love to see something like this but run it behind the front light... stealth and you can some clearance..
What about the ECU, would you need a custom tune with the added intake length?
double_0_xx is offline
post #5 of 6 Old 06-04-2010, 12:59 PM
XXed's Avatar
I just bought an Artic Cat lol. Im keeping the XX for trail riding or trying to sell the XX. (Its in the classifieds) Got way too much mud around the house NOT to have a UTE!
XXed is offline
post #6 of 6 Old 06-04-2010, 04:52 PM
I would tend to lean towards leaving the filter as is and running PVC out the back like you said. Then silicone the cowl on the air box lid shut and silicone the cover on. Theorectically your snorkel should be less restrictive that way because the filter stays closer to the intake. And you still have the original filtration system intact. This would also take care of the engine vent tube that runs into the airbox. You would still need to do something with the other breathers tubes though.
