What oil is everyone using? - Club700XX - Honda TRX700XX Forum
post #1 of 41 Old 05-24-2010, 10:04 PM Thread Starter
blk84's Avatar
Just curious what type of oil people are using for the 700. I just bought mine and want to do an oil change soon. I had a Raptor 660 before and used Mobil 1 synthetic oil (non-energy conserving) 15w-50 because of the wet clutch.
I'm assuming the 700 has a wet clutch, correct? I saw a Mobil 1 10w-40 synthetic 4-stroke oil specifically designed for wet clutches. I might try that.
Anything else people use?
08 700xx aka hillclimber
"If you want something done right, do it yourself"
Dominated...
SW, PA
Wellsville, OH
Buffalo Mtn, WV
Little Coal River, WV
Bearwallow, WV (every blk/red trail)
Rockhouse, WV (every blk/red trail)
Indian Ridge, WV
Pinnacle Creek, WV
blk84 is offline
post #2 of 41 Old 05-25-2010, 05:30 AM
atleastitsnotaford's Avatar
I use Honda GN4 oil (10w 30) I've used the Honda GN4 oil in everything I've ever had with a wet clutch, and never had a problem with it. It exceeds the manufacturer's requirements for any bike or atv out there, and costs way less than the synthetics.
Truth is any oil with the right API rating will work just fine. Just check the label and pick your flavor. (Mobil 1 synthetic exceeds manufacture's requirements too.)
atleastitsnotaford is offline
post #3 of 41 Old 05-25-2010, 06:32 AM
A lot of people use GN4. I do myself. And yes, the XX has a wet clutch.
post #4 of 41 Old 05-25-2010, 08:09 AM
I recently installed a Matlock Racing clutch and was told by him not to use synthetic, Sucks as I just changed it. Anyone running Honda synthetic on there XX?
post #5 of 41 Old 05-25-2010, 08:44 AM
post #6 of 41 Old 05-30-2010, 04:08 AM
I ran it in my 400ex,It might of been synthetic blend? It was Honda oil did'nt have any problems with it other than price. So I changed to Shell Rotella .I change it every 2 or 3 rides so its cheaper.
D.Shobe is offline
post #7 of 41 Old 05-30-2010, 05:31 AM
trx tas's Avatar
is honda hp4 synthetic
trx tas is offline
post #8 of 41 Old 05-30-2010, 06:04 AM
No, HP4 is the conventional.
post #9 of 41 Old 05-30-2010, 10:59 PM
hp4 is the synthetic/conventional blend without moly
D.Shobe is offline
post #10 of 41 Old 02-08-2011, 08:11 AM
holy700xx's Avatar
I run the Honda synthetic oil in my xx.
holy700xx is offline
