Starting your 700 - Club700XX - Honda TRX700XX Forum
post #1 of 27 Old 06-12-2010, 01:47 AM Thread Starter
Superswire's Avatar
Starting your 700
Wasn't quite sure where to post this one...
does anyone ever start thier quad and if you dont give it any gas or anything it wil stall after a few seconds then when you restart it it will idle forever ?
my quad only did this to me when it was cold and sitting for a spell, but i was just wondering if anyone has had this issue at all ?
also how slow does your bike crank over ? mine seems like its really struggling past the compression stroke and then BAM starts idling...seems normal to me for a hi-comp engine, just wonderin' tho...
i'd stil rather a kicker, lol
Superswire is offline
post #2 of 27 Old 06-12-2010, 02:50 AM
markas214's Avatar
I always start mine unless I'm just moving it across the garage. Then I'll just push it.
Mine idles fine even when cold which in Arizona is 60 degrees F.
Renthal 13 tooth sprocket
Alba Pro Elite nerf bars
CCP steering damper
L8ton Racing 9/16 Swaybar
Teixeira upper a-arms
Powermadd handguards
markas214 is offline
post #3 of 27 Old 06-12-2010, 03:29 AM
Mine starts everytime with out me giving it any gas and will sit and idle till I turn key off
Captamer71 is offline
post #4 of 27 Old 06-12-2010, 04:12 AM
OzLinc's Avatar
We have had this issue. It was the de-comp sticking. That was with a WEB cam.
OzLinc is offline
post #5 of 27 Old 06-12-2010, 11:14 AM
USMC0861's Avatar
mine does it
USMC0861 is offline
post #6 of 27 Old 06-12-2010, 12:00 PM
Mine does it almost every time. Did it stock and does it now with big 3.
post #7 of 27 Old 06-12-2010, 12:22 PM
Superswire,
When it is really cold, the machine is a little slow to crank but I think it may be a function of the oil viscosity. I use Honda10/40 all time and I suppose I should use something a little thinner during the winter. I never try to gas the engine when it is cold. It will stall every time. Never gas it before attempting to start it. This fuel injection is really touchy about this. The book recommends against it also. I use the "Battery Tender" all the time when the machine is not being used. It is a good idea to run The XX once and a while during down time just to keep the seals fresh and the injectors clean. By-the-way, after the engine warms up a little and you are ready to ride, you will notice that the machine will lurch forward a little when you put it into gear. I think that is due to the clutch plates somewhat stuck together.
post #8 of 27 Old 06-12-2010, 12:43 PM
scameron92's Avatar
Mine does it. Every time I start it, it will idle for 15 seconds or so and then stall. After starting it the second time it will idle fine.
2008 trx700xx
1992 250x (sons)
2005 crf230
2005 LTZ250 (sons)
scameron92 is offline
post #9 of 27 Old 06-12-2010, 02:38 PM
Mine idles for 2-3 seconds then dies.
post #10 of 27 Old 06-12-2010, 03:47 PM
Mine does the same thing but if I give it a little bit of gas, the issue disappears.
