Recommended grips for Dual Gasser - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 06-13-2010, 05:02 PM Thread Starter
I just purchased a Moose Racing Dual Gasser for the beast. I like the fact that you can use it as a thumb or twist throttle depending on where/how you are riding that day.
I have never had to change grips before but it seems pretty straight forward. Which grips will work with the Dual Gasser? Some have closed ends and others open for end caps like the originals. Why? Sorry neebie here...
Sgt Fury is offline
post #2 of 6 Old 06-13-2010, 05:23 PM
USMC0861's Avatar
its really a personal choice thing, just make sure you get bike style grips because of the increased diameter of the throttle tube. I normally get scott grips with the closed end then cut them out to allow stock bar ends...hope this helps, welcome to the site
USMC0861 is offline
post #3 of 6 Old 06-13-2010, 06:20 PM
VelociRaptor's Avatar
I am an Oury fan myself.
Bo White
205-886-7043
VelociRaptor is offline
post #4 of 6 Old 06-13-2010, 08:37 PM
post #5 of 6 Old 06-13-2010, 10:41 PM
I would get closed end grips if you aren't using wrap around hand gaurds. And you want dirtbike grips, as the right will be slightly bigger than the left. I am running the moose as well, just be sure to keep the lil nob lubed up
post #6 of 6 Old 06-13-2010, 11:20 PM
yeah i saw crw45's set up looked really cool and clean... i cant remember but i think the twist stuck a lil
