Radiator fan - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 06-21-2010, 08:21 PM Thread Starter
Radiator fan
Ran my quad for about 10 minutes in 85 degree temps and could not get my fan to come on, anyone know how to check the fan out?? Is there a way to get it on without getting too hot??? It does freespin but I could not get it to turn on automatically.
thevinstigator is offline
post #2 of 10 Old 06-21-2010, 08:25 PM
https://www.club700xx.com/vb/showthread.php?t=3924
This should help a little . I have same problem. Thinkin ETC sensor.
post #3 of 10 Old 06-21-2010, 08:25 PM
mine kicks on all the time? i ride with a predator, yfz, and ltz and they all kick on when riding! are you just idling?
post #4 of 10 Old 06-21-2010, 08:38 PM
Quick check is :
Turn ignition on
Unplug the sensor on the thermeostat housing.
The fan should come on and the MIL (engine) light should blink 7 times.
I have checked everything and it is pointing towards the ETC sensor.
I have not got my new ETC sensor yet , so I do not if my testing is accurate.
I will let you know.
post #5 of 10 Old 06-22-2010, 06:42 PM Thread Starter
I ran the engine at idle for about 10 minutes then started to rev the engine a little bit (<1 minute) then ran in first gear up and down my street for about 5 minutes. After all this time fan did not come on, in W Va 3 weeks ago riding the road with pants zipped off at the knees, I felt the fan come on every time I stopped. I will check the thermostat wire this week and post my results.
post #6 of 10 Old 06-23-2010, 04:29 PM
yama450yfz's Avatar
Originally Posted by Baxter View Post
Quick check is :
Turn ignition on
Why don't you just find out what continuity is for the ETC and test instead of spending money on a new one.
Live to Ride Ride to Live
yama450yfz is offline
post #7 of 10 Old 06-23-2010, 05:01 PM
It's like $13 for a new one. The problem is if it is not etc sensor then it is the ECM.
post #8 of 10 Old 06-27-2010, 08:00 AM
even if you checked for continuity, it would tell you anything but if its open or closed curciut, its a sensor itrs just a resistor, it has a certian ohm and different tempertures, i do heating and air conditioning i do this all the time. but i have to run my bike pretty hard to make it come one. if your tempo light isnt somning on i wouldnt be too worried
graysuperduty is offline
post #9 of 10 Old 06-27-2010, 08:07 AM
Superswire's Avatar
Mine takes a while to come on, usually have to be going pretty slow for it to come on, as superduty said, i wouldnt worry unless your temp light comes on, i'm sure the manual tells you how to check everything, download yourself a copy...
Superswire is offline
post #10 of 10 Old 07-05-2010, 04:54 PM
Quick check is :
Turn ignition on
My ECM is buggered . Need to order a new one.
