Spark arrestor? - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 06-26-2010, 08:07 AM Thread Starter
Spark arrestor?
Hey everyone recently purchased full barker exhaust. I thought it was coming with a spark arrestor, but did not. My one friend is telling me that i def. need one and the other is saying i dont. Just wondering are they needed or not? Thanks again
hondatee is offline
post #2 of 14 Old 06-26-2010, 08:23 AM
trizz's Avatar
most places require the use of a spark arrester if you ride wooded and desert areas its a must due to all the sage and dry brush, look at what happened in the Calif area, its a must.. big ticket if your pulled over by a ranger...
trizz is offline
post #3 of 14 Old 06-26-2010, 10:51 AM
You could get a big fine riding without one. I think it would be in your best interest to get one.
post #4 of 14 Old 06-26-2010, 12:02 PM
You could also rig up a thin metal screen under the cap. That's what most of them basically are
post #5 of 14 Old 06-26-2010, 12:25 PM
Superswire's Avatar
Yeah, big trouble for a little screen, get one or as mentioned make one, better safe than sorry, some states may even impound you for not running one...
Superswire is offline
post #6 of 14 Old 06-26-2010, 02:31 PM
skier207's Avatar
Or even worse than a fine. You could potentially start a fire like the 15,000 acre forest fire we have in northern Az right now.
Personally I would put a spark arrester in it.
skier207 is offline
post #7 of 14 Old 06-26-2010, 03:39 PM
Superswire's Avatar
Yup...you know what smokey sez...
"ONLY YOU CAN PREVENT FOREST FIRES"
post #8 of 14 Old 06-27-2010, 01:15 PM Thread Starter
thanks for the answers i figured i needed one but i figured id also ask just to make shure. There not the pricey either, its just another thing i need again. Another question would the spark arrestor from the stock pipe fit the barker at all?
hondatee is offline
post #9 of 14 Old 06-27-2010, 03:13 PM
trizz's Avatar
No buy the barker straght up...
trizz is offline
post #10 of 14 Old 06-27-2010, 03:16 PM
I have seen flames pop out of an exhaust, but has anyone seen sparks? And by sparks I mean with enough intensity that they could land on the ground and start a fire? I for one have never seen this unless an engine came apart on a dyno.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
