Kills on idle - Club700XX - Honda TRX700XX Forum
post #1 of 55 Old 06-27-2010, 06:43 PM Thread Starter
Kills on idle
Anyone else have this issue?
I changed the plug and changed the tune to a known working tune and it still will only idle for a few seconds.
My quad doesn't smoke. (nor do I)
It [the killing part] is pissing me off.
post #2 of 55 Old 06-27-2010, 06:46 PM
redrider's Avatar
Tried taking the fuel controller out of the loop?
redrider is offline
post #3 of 55 Old 06-27-2010, 07:19 PM
redrider's Avatar
maybe its a flaky thing with the computer, try to disconnect the battery overnight, let all the capacitors drain down, maybe it will forget why its killin itself?
redrider is offline
post #4 of 55 Old 06-27-2010, 07:45 PM Thread Starter
I don't want to remove the controller as it I believe it will only make it run worse since I have the slip on.(I realize you were't saying permanently, but none the less)
I have never adjusted my valves, could it be that?
post #5 of 55 Old 06-27-2010, 07:59 PM
redrider's Avatar
yeah, i was just mainly thinking disconnect the controller (plug back in as it came from the factory) to see if it will idle (assuming it was easy to take out of the loop). If it idles then you've found the culprit, if not you've ruled something out. Really sounds like a quirky computer problem, have the same issue with my truck sometimes (check engine light), the battery disconnect issue fixes it everytime.
Dont necessarily think it would be the valves out of adjustment, but easy enough to rule out as well you havent adjusted them yet...
redrider is offline
post #6 of 55 Old 06-27-2010, 08:29 PM
skier207's Avatar
I would by pass the controller first. Should only take a few minute's, just unplug it at the injector and reconnect your factory injector wire. A valve adjustment is never a bad idea either.
skier207 is offline
post #7 of 55 Old 06-27-2010, 08:29 PM Thread Starter
I'll take a look tomorrow and see, I already dropped it off at storage.
Yeah, I forgot the KISS concept....
post #8 of 55 Old 06-27-2010, 08:36 PM
trizz's Avatar
download the manual, check the codes from the ecm by counting the flashes from the check engine light, use the manual for reference, if you have a after market fuel controller pull it out of the loop,clear all codes recheck your engine, run it up if it still does the same thing pull the codes again go back to the manual for reference check the air filter and so-on
trizz is offline
post #9 of 55 Old 06-27-2010, 08:38 PM
redrider's Avatar
Heh, kiss, gotta love over engineering, on second thought... not idling, sounds like a good time to pull the engine out and go through it.
redrider is offline
post #10 of 55 Old 06-27-2010, 08:38 PM Thread Starter
I think I'm one of the few who actually bought the manual...
lol!
