EHS Lid Install Question - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 07-02-2010, 02:33 PM Thread Starter
kygoat's Avatar
Do ya leave the air filter guard under the lid off when you reinstall?
'05 Wolverine
kygoat is offline
post #2 of 14 Old 07-02-2010, 02:49 PM
Yes, leave it off. (well, I did)
I believe the instructions tell you to take it off but they don't tell you to put it back on, so I assume that means leave it off.
I wondered the same thing.
post #3 of 14 Old 07-02-2010, 03:00 PM Thread Starter
kygoat's Avatar
Thanks. Honestly I was thinking ya actually got a lid with the air element already attached. No biggie though...
'05 Wolverine
kygoat is offline
post #4 of 14 Old 07-02-2010, 11:04 PM
I put mine back on. More protection
post #5 of 14 Old 02-26-2011, 03:36 PM
nbarabino's Avatar
Send a message via MSN to nbarabino
Hi, I am determined to bring the EHS Racing Big 3. I wanted to know if the installation requires a qualified mechanic in the injection or placement is simple. What do you recommend? Besides the Big 3, there is another package that surpasses it?
Greetings
TRX 700 XX 2008
Spacers 4 wheels
Kyle8tone sway bar
13t front sprocket
15t front sprocket
9" wheels 20X11X9 (Kenda klaw)
nbarabino is offline
post #6 of 14 Old 02-26-2011, 03:58 PM
I left mine off as well.
post #7 of 14 Old 02-26-2011, 04:46 PM
No necesitas mecanico para instalar el kit. Tu solo puedes con un poco de herramienta. Por el $ es una de las mejores modificaciones que puedes hacer. Compralo y jamas te arrepentiras.
You don't need a qualified mechanic to instal the kit. All you need is a couple wrenches. For the $ it's one of the best mods you can do. Buy it and you will never regret it.
Greetings
chubbycheddarTRX is offline
post #8 of 14 Old 02-27-2011, 02:57 PM
nbarabino's Avatar
Thanks I will try to do it
TRX 700 XX 2008
Spacers 4 wheels
Kyle8tone sway bar
13t front sprocket
15t front sprocket
post #9 of 14 Old 02-28-2011, 12:22 PM
trx700's Avatar
I took mine off the stock lid to get more air when I replaced the filter with an UNI.
2008 Black & Red TRX 700XX
trx700 is offline
post #10 of 14 Old 02-28-2011, 03:32 PM
I kept mine on.
