Stalling - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 07-05-2010, 07:02 PM Thread Starter
240
Stalling
I cleaned and re-oiled my air filter and now my bike stalls sometimes in neutral and a bit more on slow technical trails. I have EHS programmer is my bike running to rich or lean?
240 is offline
post #2 of 11 Old 07-05-2010, 07:07 PM
Did you put the freshly oiled straight in and go and play ?
Did your fan come on at all ?
post #3 of 11 Old 07-05-2010, 07:09 PM Thread Starter
240
No I oiled, squeezed, patted dry with paper towels and let it sit for 48 hours before riding. The fan was coming on here and there.
240 is offline
post #4 of 11 Old 07-05-2010, 07:11 PM
What other mods are running , Big 3 ?
post #5 of 11 Old 07-05-2010, 07:11 PM Thread Starter
240
yeah full barkers
240 is offline
post #6 of 11 Old 07-05-2010, 07:16 PM
This may help you out . It lists the numbers you should be running.
Just check them. It is easy , just follow the instructions.
https://www.club700xx.com/vb/showthread.php?t=4129
post #7 of 11 Old 07-06-2010, 08:54 AM
post #8 of 11 Old 07-06-2010, 03:15 PM
you may just need to adjust your idle. The physical one not on the controller, you can also lower the green blue setting to get fuel to start being added earlier. 99% of ideling and under 1400rpm issues on almost all efi atv's are caused by tps out of calibration or throttle plate being set wrong.
your above scenario wont change anything other than if you sucked oil from the filter in and fouled a plug
scuzz but your case you just need a new controller lol
EHSRACING is offline
post #9 of 11 Old 07-06-2010, 06:21 PM Thread Starter
240
How do I adjust the idle?
240 is offline
post #10 of 11 Old 07-07-2010, 02:14 PM Thread Starter
240
lol I checked the service manual and all I could find was how to check the idle nothing about adjusting it. I will try adding fuel to the green blue and see how that goes I guess.
240 is offline
