Has anybody had this problem?? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 07-06-2010, 12:48 AM Thread Starter
hmfman91's Avatar
I had my XX pinned back in 5th gear wide open the other day and it just quit. I had a good pull goin in 5th and it felt like it hesitated sputtered and shut off so I just pulled the clutch in till i stopped, but when i stopped it was still running. Its never done that before so i thought that maybe my EFI tuner was messed up but it wasnt. I was also thinkin that maybe the injector wasnt puttin enough fuel to the cylinder... idk wat happened. It runs fine now and hasnt missed a lick. Any info is highly appreciated. Thanks
2008 RED/BLACK 700xx
hmfman91 is offline
post #2 of 6 Old 07-06-2010, 01:43 AM
IDK what to tell you. The first part seemed like it would indicate your clutch, but if it is running fine and everything it definately isn't that.
post #3 of 6 Old 07-06-2010, 06:25 PM
240
Only time that's happened to me is when I'm running low on gas.
240 is offline
post #4 of 6 Old 07-06-2010, 07:14 PM
Actually I just thought of something. When you were in 5th gear pinned, was it flat, like a road? Cuz mine has been eating oil when I was in HM, and it stalled on me while I was going down the road due to LOW OIL LEVEL, so did you check your oil? Just a thought.
post #5 of 6 Old 07-07-2010, 11:15 AM
mine will do this if its getting low on fuel and if its not warmed up and i try and get on it it will cut out and die when im on the pipe
post #6 of 6 Old 07-07-2010, 05:43 PM Thread Starter
hmfman91's Avatar
Well maybe it didnt have enough gas. I feel kinda dumb now for not checking it lol. Thanks everyone
hmfman91 is offline
