fmf fuel controler - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 07-07-2010, 06:11 AM Thread Starter
fmf fuel controler
got a chance to get hold of a fmf fuel controler cheap,im running a hmf slip on at the moment without an after market controler, just a few questions who else is running one of these? and are they any good?will i notice much power difference with it on?
aussie700xx is offline
post #2 of 8 Old 07-07-2010, 07:03 AM
trx tas's Avatar
you will probably not notice any power difference with the controller however it is a good idea to run one anyway
trx tas is offline
post #3 of 8 Old 07-08-2010, 08:50 AM
Superswire's Avatar
You may not feel the difference, but when you put an aftermarket pipe on you are flowing better really making it a bit leaner and these are lean from the factory and although you have an intake air temp sensor that should richen up your mixture, they really dont do much. What you will do by programming your fuel correctly is make more power not only by supplying the extra fuel you need for the extra air velocity, but the extra fuel will cool your intake air and help to keep temperaturs down also making more power...theres alot more technical stuff along with it, but definately a good idea to run a controller man, definately !!!
Superswire is offline
post #4 of 8 Old 07-08-2010, 03:56 PM Thread Starter
should have it in the mail early next week hopfully,reakn ill go a better flowing airfilter aswell
post #5 of 8 Old 07-09-2010, 04:01 PM
Aussie, go to the powercommander.com website, and you can download the setting for your pipe and stuff from there, that they set up. I know for a fact that they have a map for just a slip on.
post #6 of 8 Old 07-09-2010, 08:04 PM
Superswire's Avatar
someone on here has a full map also, i forget who, but ask and ye shall recieve i'm sure, thats waht were here for...gotta keep our 700s ahead of the competition LOL
post #7 of 8 Old 07-11-2010, 03:23 PM
i run a fmf programmer with a uni filter and fmf power core 4 slip on. i did notice a difference especially when im just putting along.( which doesnt happen often on an xx lol.) but my buddy's bike is stock and the is definetly a difference between them. i havent had the chance to change any of the settings on my programmer but so far i really havent found the need to.
OFUD is offline
post #8 of 8 Old 07-20-2010, 02:23 AM
markas214's Avatar
FMF is a Dobek controller. No downloads.
Renthal 13 tooth sprocket
Alba Pro Elite nerf bars
CCP steering damper
L8ton Racing 9/16 Swaybar
Teixeira upper a-arms
Powermadd handguards
markas214 is offline
