valves need help - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 07-07-2010, 02:55 PM Thread Starter
valves need help
o.k guys i removed everything to do my valves. turned engine over and looked in the small hole where you line up the h mark. adjusted the valves. i have found a possible problem, after the first T mark turning clockwise about 10mm after the first H i have a second H, is this normal if so do i use the first H mark or the second. second thing do you adjust inlet valves then turn crank one complete revolution and adjust exhaust. or are they adjusted all at same time as inlet without turning crank,
cheers gary
mods to my trx700xx
corsasri is offline
post #2 of 7 Old 07-07-2010, 03:16 PM
If I'm not wrong, it should be the first one, one way to verify is when the mark is centered, does your valve move freely? They should be loose enough to notice
post #3 of 7 Old 07-07-2010, 03:56 PM
cheers gary
One of the marks is a line with a "T" sideways. This is the one you want .
Line the "T" up and check all rockers are loose. If some are tight with no free play , then rotate 360 degrees and check again.
Once all have play in them check them all .
In = 0.15 mm
Ex = 0.20 mm
post #4 of 7 Old 07-07-2010, 09:35 PM
Just like Baxter said, TDC on the compression stroke is where you want to be. The cam will make one revolution while the crank makes two. That is why you have to make sure you are on the compression stroke by verifying that the valves have some play.
post #5 of 7 Old 07-08-2010, 12:42 AM Thread Starter
so once at tdc and on the compresion stroke do i adjust all 4 valves. or only adjust 2 then turn crank 180 and check the other 2 ?
mods to my trx700xx
corsasri is offline
post #6 of 7 Old 07-08-2010, 04:39 AM
b.courtney_700xx's Avatar
all at once
2008 trx700xx
dg steel series nerf bars
13t renthal
3D powertip
razrs on her feet
b.courtney_700xx is offline
post #7 of 7 Old 07-08-2010, 04:57 AM
VelociRaptor's Avatar
Yep, the rockers will be on the base circle of the cam at TDC when the plug fires so thats an ideal place to adjust your valves. Like was posted, the piston comes to TDC twice, once with all the valves open and once with all the valves closed(when combustion occurs when the plug fires).
Bo White
205-886-7043
VelociRaptor is offline
