to do valves or not - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 07-09-2010, 01:28 AM Thread Starter
trx tas's Avatar
to do valves or not
so i am going to break into the engine around christmas have shop lined up already so far we are doing a stage 3 hot cam 11.1 cp piston throttle body 46mm and a port and polish and dyno tune my question is it worth doing valves for the extra 800 dollars money not really the issue(will be a issue if i have to rebuild all the time) but i am wanting reliability at the same time as power and as he said you will not notice any earth shattering performance gains with the +1mm valves
trx tas is offline
post #2 of 11 Old 07-09-2010, 03:59 PM
You wont notice hardly anything w/ just a +1mm unless you are doing a lot more engine mods. There is some benefit, but not much, in performance wise and with an everyday rider that isn't doing this for a living, you probably wouldn't notice much at all. This is coming b/c I am going thru all of this right now. I am doing the 730 kit, stage 2 cam, and redoing all the valve seats, and after checking data, there isn't much difference btwn valves (coming from Dyno sheets for 450s which I know is a completely different machine, but it can't be much difference). The only thing you're doing that I haven't looked into that much is the throttle body.
post #3 of 11 Old 07-09-2010, 08:10 PM
Superswire's Avatar
i may be wrong, but if i was doing what you were, i would think the extra lift and duration should handle the extra flow of the throttle body without huge valves ? maybe a set of kibblewhites or something of the sort and some performance springs will help you though ?
Superswire is offline
post #4 of 11 Old 07-09-2010, 10:30 PM Thread Starter
trx tas's Avatar
thats all i was going to go was a set of kibble white valves and springs i was going to do a port and polish aswell
trx tas is offline
post #5 of 11 Old 07-09-2010, 10:59 PM
Superswire's Avatar
did you ask velociraptor or alba themselves maybe ? i think you should really weigh the options i mean if its BIG hp then yeah, i just dont think it will be dramatic enough but thats my opinion...
post #6 of 11 Old 07-09-2010, 11:46 PM
Just a heads up if your interested this fall I will be selling my complete topend and 46mm taper bored throttle body
08 raptor 700
chris is offline
post #7 of 11 Old 07-10-2010, 01:06 AM Thread Starter
trx tas's Avatar
how much mate what have you done to your top end
trx tas is offline
post #8 of 11 Old 07-10-2010, 01:20 AM
Bo White ported head with +1mm intake valves, web stage3 cam, web hardwelded rockers, web valve springs and retainers, and a alba 46mm taper bored throttle body. There is pics on the forum of the head finished ported. I've not decided on a price yet but for the right one I'll pull it apart right now.
08 raptor 700
chris is offline
post #9 of 11 Old 07-10-2010, 01:25 AM
Here is a link to pics of the head https://www.club700xx.com/vb/showthread.php?t=3200
08 raptor 700
chris is offline
post #10 of 11 Old 07-10-2010, 01:46 AM Thread Starter
trx tas's Avatar
think about a price mate and pm me
trx tas is offline
