Quick question about UNI filter-> - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 07-13-2010, 06:31 AM Thread Starter
I thought I had read on here somewhere that with the Uni filter you could separate the two layer's of foam for cleaning and oiling purposes? Well I got my 2 Uni's in the mail yesterday and noticed that is not the case? Mine came looking just like the stock filter only red? I did notice the cage had bigger openings. So it should flow better, but I was hoping to be able to take the foam apart to help in servicing the filter. Did I order the wrong ones or do they not come like that? I'm confused... Suggestions?
post #2 of 13 Old 07-13-2010, 08:16 AM
post #3 of 13 Old 07-13-2010, 08:21 AM
kygoat's Avatar
Same. Just got mine. I also oiled the inside of the airbox.
'05 Wolverine
kygoat is offline
post #4 of 13 Old 07-13-2010, 08:28 AM
I never really heard what you are talking about with the UNI's, all I have encountered are one complete thing of foam. Someone could of meant seperating it from the cage so that you can oil the inside of the of the filter. It is not just about the cage having bigger openings to flow more, the foam in itself is better than stock.
post #5 of 13 Old 07-13-2010, 08:39 AM Thread Starter
Ok cool, I don't know where I heard that about being able to take the foam apart?
post #6 of 13 Old 07-13-2010, 09:45 AM
The Uni foam filters for the raptor can be separated. Yellow is the finer foam beneath and read is the coarse one on top, you can separate, clean and oil both of them apart.
2006 Raptor 700
post #7 of 13 Old 07-13-2010, 09:48 AM
post #8 of 13 Old 07-13-2010, 10:17 AM
You're supposed to oil them? No wonder my motor is wheezing now. j/k
post #9 of 13 Old 07-13-2010, 10:51 AM Thread Starter
Ok so on the Rappy's you can separate the foams! I wish you could do that on the XX's Uni filter. It would make it easier to get the two layers cleaned and oiled.
post #10 of 13 Old 07-13-2010, 03:11 PM
mine is the same way.
StepNez is offline
