Smoking on Decel?? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 07-17-2010, 02:46 PM Thread Starter
Smoking on Decel??
Seems everytime I hammer it and let out, it puffs white smoke. Not really losing any coolant nor does it smoke under throttle. Normal or should i let the stealership check it out? Quad only has about 30 hours or so on it!
Only mods are uni filter and EHS lid
'08 700xx - EHS lid, Uni, 13T, Razr2's/ITP T-9s and HIDs
'05 Hayabusa - Carpenter Racing 1397cc - 208hp
'03 Cobra - 302 Stroker, Cammed, Whipple
'97 F250 Powerstroke
'72 Chevy C10 - 350 Project truck
1985mustanggt50 is offline
post #2 of 7 Old 07-17-2010, 03:17 PM
Did you put too much oil on the filter? I did once and it smoked a little on decel. But it went away after a couple rides.
post #3 of 7 Old 07-17-2010, 03:27 PM
DEF sounds like too much oil in the filter. I would just take the filter off and pat it dry on the inside and out to get any excess oil out. Then pull your plug and clean it/replace it (that way if it keeps smoking you can check the plug). if it was regular oil it'd be more blue, trust me I KNOW lmao. Also, just check to make sure your engine oil level is good.
post #4 of 7 Old 06-03-2013, 12:45 PM
I went in a big mud hole and had to pull it out. I Chang the oil but white smoke is comes out when i push the gas at idel it don't smoke what you think?
bebob32 is offline
post #5 of 7 Old 06-03-2013, 12:55 PM
sounds like you still have water in your oil
post #6 of 7 Old 06-03-2013, 06:22 PM
Did you fit a EFI programmer ?
post #7 of 7 Old 06-03-2013, 09:56 PM
Ru really replying to a almost 3 year help post? I'd hope he figured it out by now...
Just messing with you, and I know it wasn't you that woke the dead thread...
