Thank god it's a Honda, now what? Please help. - Club700XX - Honda TRX700XX Forum
post #1 of 38 Old 07-28-2010, 03:33 PM Thread Starter
mgftp's Avatar
Hey all, hoping some mechanically inclined peeps can help me out.
Today I tried to hug some high ground which I could not fit on and ended up putting myself and my 700 in the drink, submerged in water. The 700 stopped running as I was waist deep in it. I pulled her out as fast as I could (damn this thing is heavy) and quickly checked my air box to see it was now a fish tank. I honestly thought I was screwed as far as getting it running again today but after putting the thing on itís side and up on the rear bar (did I mention this thing is heavy?) gallons of water poured out and I got it started to watch water spew from the exhaust for a minute or more. Relieved I would not have to walk miles home just to have to come rescue my 700 another day, the bike rode back what seemed flawlessly.
So now that my 700 is sitting in my garage licking the wounds I gave it. Have I done any damage? If so how much? What? What can I and should I do or check at this point?
And for the record maybe another bike would take this and keep on going too but I sure have abused some Hondas in my day and at this point will never buy anything else with an engine that is not a Honda. I absolutely beat the living .ish out of my first Honda CBR sport bike and the thing ran like new with just regular maintenance up to 25k when I sold it. I now even have a Honda lawnmower and am getting a Honda pressure washer. I am thankful that a company can make such reliable equipment. I think they are the only company that has actually sold me on their brand.
mgftp is offline
post #2 of 38 Old 07-28-2010, 03:45 PM
I would say check the plug and check the oil for water. I would take the air filter off and let it dry out good. Make sure the fuse area is dry so it does not corrod.
lager1 is offline
post #3 of 38 Old 07-28-2010, 03:46 PM
your pretty lucky, two weeks ago my friend did the same thing to his honda foreman. sat it up pulled the spark plug water shot every where it started. i cant wait to see if it blows smoke or not its hard to hydro lock a motor and have it come out fine honda or no honda.
graysuperduty is offline
post #4 of 38 Old 07-28-2010, 03:46 PM
Your going to need to drain the oil and change your filter about 2-3 times. Change it let it get to temp, then change it again. May take only 2 times if your lucky.
NineLivez2Go is offline
post #5 of 38 Old 07-28-2010, 04:18 PM
i drowned a yammie 450 i used to own we drained the oil,removed the plug and filled engine with metholated spirits wound it over for a minute or so(metho evaporates any water/moisture that will be in the engine sitting on gears/bearings ect that will cause rust spots and cause things to fail)then replaced oil filter filled with oil and went for a ride, then drained oil and replaced filter again, rode as normal after this, i had the bike for 4 years after this and had no probs at all
aussie700xx is offline
post #6 of 38 Old 07-28-2010, 04:37 PM
traitor08's Avatar
I would also add check all electrical connections and put a little dielectric in every connection that doesn't have waterproof connections. It doesn't take much corrosion to mess up a ride.
traitor08 is offline
post #7 of 38 Old 07-28-2010, 05:29 PM
TRX700XXX's Avatar
Did the same to mine and still works like brand new.
TRX700XXX is offline
post #8 of 38 Old 07-28-2010, 05:43 PM
It's been my buddies experience (the skimers) that you need to change the oil at LEAST 6-7 times to get all the water out.
post #9 of 38 Old 07-28-2010, 05:46 PM
Good to know, thanks Scuzz. I have never had the pleasure on my quad but had a buddy who swamped his truck and it took 3 oil changes to clean it out.
post #10 of 38 Old 07-28-2010, 07:14 PM
My Buddy swamped his brute force and after changing the oil like 10 times it still developed a smoke and had to go to the shop.
