Clutch problems - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 08-01-2010, 01:30 PM Thread Starter
Clutch problems
Hi!
3 months ago I changed my clutch, all plates + Springs, because it slips on higher Gears, and everything has worked great until a few weeks ago when it began to slip again, but now only when the engine is cold, when the engine is hot it works good.
One problem I noticed is that when I start the engine and keeps clutchhandle in with first gear, it's Seems like the clutch is not released and the machine make a jump forward and engine stops, then i can start and it's working ok , But still it's slipping on High Gears until the engine is warm, i have tryed 2 differnt OIL so i dont think thats the problem...
Someone who has had similar problems or any solutions to this wery enyoing problem, clutchkit is EBC Dirt Racer clutch with heavy duty springs.
lgedlund is offline
post #2 of 7 Old 08-01-2010, 02:33 PM
Check the amount of play in the clutch cable, sounds like may be a bit tight also how much oil are you putting in the engine when you change?
post #3 of 7 Old 08-01-2010, 03:02 PM Thread Starter
Thats allready checked i put in 1,8 liters when i change oil + filter, i dont know if its the start in cold engine and when the clutch have soak together thats making it a little weaker every time?
lgedlund is offline
post #4 of 7 Old 08-01-2010, 03:27 PM
I have had some clutch problems and cured them by putting 2.1 instead of the standard 1.8 litres in when i change the oil and filter .
post #5 of 7 Old 08-01-2010, 05:14 PM
I put 2qt
lager1 is offline
post #6 of 7 Old 08-01-2010, 07:00 PM
Sounds like maybe just not enough oil...or dirty oil.
post #7 of 7 Old 08-02-2010, 03:04 AM Thread Starter
I change oil every 10 hour, so i dont think the oil is the problem, I will try to put in some more oil and see if that helps. Thanks for respond ;)
lgedlund is offline
