about 60 hours what do you do? - Club700XX - Honda TRX700XX Forum
post #1 of 2 Old 08-02-2010, 11:33 PM Thread Starter
So i am at about 60 hours or more maybe...what do you do?
It feels different for some reason, i had full 20-25 hour with valve adjustment...
Oil changed before every trip
Spark plug? Coolent change...what do you use? What about adjusting the valves again?
UpOnGaMe is offline
post #2 of 2 Old 08-03-2010, 03:07 AM
Check the plug if you want, but the plugs usually run a very long time. Also, if you have the means, why not check the valves? IDK if this is something you do yourself, or you take it in. A good recommendation would be to check the service manual, but then again you can never do something too much right? I would check all the bolts though, everywhere, make sure they are tight, plastics included.
