Idle & Redline RPMs? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 08-03-2010, 10:28 AM Thread Starter
Anybody know what the factory idle rpm should be, and redline rpm is on our TRX 700s ? Do they have a rev limiter device installed?
Thanks in advance
Wheelman
wheelman is offline
post #2 of 6 Old 08-03-2010, 06:26 PM
Im not sure, but I would check the service manual that you can download in the HOWTO section. It should be in there. I'd check mine, but sadly I'm at work.
post #3 of 6 Old 08-03-2010, 06:31 PM Thread Starter
well I found the idle rpm in there. Its 1500 +/- 100 rpm. No sign of the redline or peak hp/tq @ rpm numbers though
wheelman is offline
post #4 of 6 Old 08-03-2010, 08:38 PM
holy700xx's Avatar
pin it and you'll hear the rev limiter
holy700xx is offline
post #5 of 6 Old 08-04-2010, 07:33 AM Thread Starter
Okay so to sum up:
  • Idle at 1500rpm +/- 100rpm
  • Does Have Rev Limiter
Still would like to know where it's set at.
wheelman is offline
post #6 of 6 Old 08-04-2010, 09:02 AM
TRX700XXX's Avatar
If you look at the dynos from two brothers, hmf, and ehs racing, they all end at about 8750rpm so I guess that's rev limiter.
TRX700XXX is offline
