Headlights Quit - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 08-10-2010, 04:58 PM Thread Starter
KJP
Headlights Quit
I recently went to ride my xx and realized the lights weren't working at night...I took the headlight off the quad and tested the harness feeding into the headlight (yes, with the light switch on and quad running!) but there's no power coming to the harness.....Anyone know what I need to try now?? Any info would be greatly appreciated.
KJP is offline
post #2 of 6 Old 08-10-2010, 05:12 PM
Did you check the fuse by chance? You probably did but thats the first thing that came to my mind.
post #3 of 6 Old 08-10-2010, 05:31 PM
Overlord's Avatar
Mate I would have a look at the switchblock and make sure it is earthed right.
Overlord
Overlord is offline
post #4 of 6 Old 08-10-2010, 06:33 PM
redrider's Avatar
does the tail light work when you switch em on? if not, betcha these guys are on to something...
redrider is offline
post #5 of 6 Old 08-10-2010, 08:34 PM Thread Starter
KJP
thanks guys...problem was in the switch..everything works when bypassing the switch with a jumper
KJP is offline
post #6 of 6 Old 08-10-2010, 09:48 PM
mrtheandrew's Avatar
did you replace it or were you able to fix it yet?
mrtheandrew is offline
