Pro Design Billet Radiator Super Cooler - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 08-18-2010, 01:17 PM Thread Starter
Has anyone here used or seen this product. It is an inline radiator cooler that states it will lower coolant temp by 5-10 degrees. If that is the case I may want to try it. It seems like my fan is running all the time. In theory it should work but I wanted your thoughts and opinions.
Thanks
http://cgi.ebay.com/ebaymotors/Pro-D...Q5fAccessories
Seabass is offline
post #2 of 3 Old 08-18-2010, 08:42 PM
av8r's Avatar
Venturi coolers can work Ford uses them on the 6.4 and 6.7 diesel. Can't tell you if this will do anything on the 700XX. Ask the seller if he'll guarantee a drop in temp or take it back.
av8r is offline
post #3 of 3 Old 08-18-2010, 09:18 PM
i have friends that have these ones if nothing else u got a temp guage.
http://www.rogueperformanceproducts....6-dd308ffa48a5
