Engine Kills When Pressing Throttle Quickly - Club700XX - Honda TRX700XX Forum
post #1 of 18 Old 08-20-2010, 06:58 PM Thread Starter
billybobsaints's Avatar
I noticed the other day that when I press the throttle quickly from idle the engine dies. This was noticed after the Big 3 install. Is this normal? Its not at the point where I have to be careful when pressing the throttle but if I press the throttle fast from idle the engine does die. Any advice?
08 700xx -EHS Big 3, 13T sprocket, l8ton Sway Bar, uni filter, ODI lock on grips, & Tusk gas cap
billybobsaints is offline
post #2 of 18 Old 08-20-2010, 07:01 PM
most vehicles would do that to some degree , most likely its general confusion as to what to do with all that extra fuel mix be my guess ..kinda like extinguishes the flame so to speak ...progressive roll on of throttle better for ya xx anyways ....leads up to an "evil" grin that cant be wiped off for days .....
Oz_Beast is offline
post #3 of 18 Old 08-20-2010, 07:26 PM
boost addict's Avatar
Something is off. You should be able to stab the throttle from any postion with fuel injection and go lol. I would contact EHS asap.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #4 of 18 Old 08-20-2010, 07:32 PM
eclipsegs0's Avatar
same thing here so if u figure nthing out let me no.. thats what i thought the engine jus died cause of all the fuel
08 trx700xx
ehs programmer
eclipsegs0 is offline
post #5 of 18 Old 08-20-2010, 08:14 PM
Reconnect the OEM computer and see what it does.
post #6 of 18 Old 08-20-2010, 08:56 PM
kygoat's Avatar
Same here. Have learned to work around it.
'05 Wolverine
kygoat is offline
post #7 of 18 Old 08-20-2010, 09:12 PM
I think that every Honda 4-stroke I have owned did this ( or does this) to some extent.
post #8 of 18 Old 08-21-2010, 07:05 AM Thread Starter
I'll be back home in a couple of weeks and see what this does.
post #9 of 18 Old 08-21-2010, 03:32 PM
I have the HMF system, and once warm it does not die on full punch of the throttle. Hope i didn't just jinx myself.
StepNez is offline
post #10 of 18 Old 08-22-2010, 03:14 AM
How the hell can you win a race if you can't punch it from the takes off at an idle I have never seen a Honda with this problem the more I read on the big 3 mod the more I say not no BUT HELL NO, its sounding like more and more trouble to me.
silliestdaddy is offline
