Which fuel controller PC3 or PCV - Club700XX - Honda TRX700XX Forum
post #1 of 21 Old 08-25-2010, 07:58 PM Thread Starter
I have a 2008 with the 13 tooth sprocket, Uni Air Filter, EHS Lid. I only have money for either the controller or exhaust right now so the controller comes first. Since you can not easily change the map on the EHS controller I was going to buy the Power Commander. Are there any real benefits to one over the other? Thanks in advance for any help...
PS - If it matters I am looking at either the Barkers exhaust or FMF 4.1 with power bomb to be my next purchase after the controller.
Sgt Fury is offline
post #2 of 21 Old 08-25-2010, 08:21 PM
av8r's Avatar
Do these "controllers" work like most and simply widen the pulse width to the injector to richen it up?
av8r is offline
post #3 of 21 Old 08-25-2010, 10:00 PM
I believe that's right. Except the Power Commanders can also subtract fuel, which I don't think the Dobeck-style units can. Plus, they can run full fuel maps like a car, complete with TPS inputs. Correct me if I'm wrong, but the Dobeck/HMF units can't do that.
Between Power Commanders, I would get the 5. I DON'T have any of these units, so I'm just going off what I've read. But the 5 is significantly smaller, and can run an Autotune if you wanted to expand in the future. To me, that's the way to go.
Tom
08 Outlander 800
08 Yamaha Big Bear 400 4x4
OHV Wildcat is offline
post #4 of 21 Old 08-25-2010, 10:14 PM
vfm2010's Avatar
I have the PC5 and love it. the biggest difference would be that you can add the autotune to the 5 which will help fine tune the fuel mapfor you, a big plus when you add mods later on.
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #5 of 21 Old 08-25-2010, 10:59 PM
droby1242's Avatar
you cant go wrong with either both are a really good controller how ever if you want the autotune feature the 5 is the way to go but i believe there are more maps for the 3.
droby1242 is offline
post #6 of 21 Old 08-26-2010, 03:12 AM
I have a power commander 5. and dont forget you can now use the old power commander 3 maps on the 5.
mods to my trx700xx
corsasri is offline
post #7 of 21 Old 08-26-2010, 03:24 AM
droby1242's Avatar
I wasnt aware of this. I thought you couldnt use the maps. I wish i would have known when i bought the PC3
post #8 of 21 Old 08-26-2010, 04:30 PM
yes im correct as i used a pc3 map for my setup.
mods to my trx700xx
corsasri is offline
post #9 of 21 Old 08-26-2010, 05:40 PM
Overlord's Avatar
Folks remember with the Commander its not just about downloading maps from the Net or elswear then going riding. To get the full benifit of the Commander you need to get it on the Dyno and that's wear the Commander really shines over other standard Fuel controllers.
Overlord
Overlord is offline
post #10 of 21 Old 08-26-2010, 07:37 PM Thread Starter
Thanks for the input. You guys are great...
PC V sounds good since it does everything the PC III does and more. Curious though. I really dont like Dyno time. Does this mean that the PC will not produce good power without the Dyno tune? I dont care about every last hp/tq. I have the PC III on my HD and it worked well out of the box.
Would the EHS setup be any better since they do a lot of work with the TRX?
Trying to be plug and play since I dont race at all.
Thanks again
Bill
Sgt Fury is offline
