Need HELP Transmission shift problems - Club700XX - Honda TRX700XX Forum
post #1 of 20 Old 09-05-2010, 08:02 PM Thread Starter
crying Need HELP Transmission shift problems
So I go out ridding today and Could not get it into 3rd with my foot for 15 mins. I finally used my hand and with clutch pulled in I used other hand to pull up several times on shifter and got it into 3rd. I kept playing with it and got it to shift better somewhat
I can rarely shift it into 3rd with my foot have to pull up 1-3 times on it to get it to shift.
I hear NO strange noises from transmission. I stopped messing with it and put it away.
I have checked all my fluids just to make sure all Im guessing NO way will honda cover this even though I have extended warranty and I have owned the quad 4 months
Captamer71 is offline
post #2 of 20 Old 09-05-2010, 08:06 PM Thread Starter
Down Shifting is easy works every time first time, Up shifting is the problem
could this be something todo with the shift fork?
post #3 of 20 Old 09-05-2010, 08:46 PM
probably bent ur shift forks a lil
post #4 of 20 Old 09-05-2010, 08:57 PM
One thing I have learned about transmission problems, the only way to know for sure what is wrong, is split the cases and inspect everything. Probably not what you wanted to hear, but it is the only way to really know what is wrong.
Check everything you can first. (Clutch, clutch adjustment, oil, etc.) If everything checks out, time to split the cases.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #5 of 20 Old 09-05-2010, 09:08 PM Thread Starter
so just take it back to dealer since I am NOT a mechanic? I can do simple stuff but that sounds way more than what I feel comfortable doing
post #6 of 20 Old 09-05-2010, 09:34 PM
droby1242's Avatar
Man the alignment sounds like a tweaked a-arm and the shifting could be shift forks or adjustment. You can take it to honda but you will be overcharged. I would just take my time and use your resources on here. Talk to av8er he just adjusted his. If its the shift forks take it in
droby1242 is offline
post #7 of 20 Old 09-05-2010, 09:42 PM
droby1242's Avatar
Alignment could also be a bent tie rod
post #8 of 20 Old 09-05-2010, 10:31 PM Thread Starter
Upshifting to 3rd gear is the only real problem it got better with me riding it around but i really dont wanna risk destroying it any ideas what a decent dealer would charge for this i wish i hadnt been stupid and wasted $500 bucks on a 4 yr warranty Alignment isnt off much left front tire is not toed in its out just a little bit tried to adjust tie rod but it is locked on so tight two men and good tools no luck but on one end
post #9 of 20 Old 09-06-2010, 08:43 AM
Fix the front end problem and take it in and play dumb. It's worth a try.
12 RZR XP900
bduncan1231 is offline
post #10 of 20 Old 09-06-2010, 09:14 AM
When you tried to get the locking nuts on your tie rod loose did you try to loosen them the same way? The outer tie rod ends have right hand threads and the inners have left hand threads. Good luck with everything
12 RZR XP900
