Cam? - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 01-15-2009, 08:07 PM Thread Starter
08TRX700XX's Avatar
Send a message via AIM to 08TRX700XX
Cam?
I have been told to expect Hotcams to come out in Feb for the XX. Was wondering if anyone had heard that or heard from any of the other companies.
2008 TRX700XX Red/Black
Two Bro's Slip On
PC3
08TRX700XX is offline
post #2 of 8 Old 01-15-2009, 08:32 PM
VelociRaptor's Avatar
Depending on the specs they probably have variations of lobe profiles that they use on the XR650R cams(that you can get now if you want).
Bo White
205-886-7043
VelociRaptor is offline
post #3 of 8 Old 01-15-2009, 10:04 PM
I Have talked to Hotcams multiple times the past 2 months and it will be late Feb or mid March.
post #4 of 8 Old 01-16-2009, 09:58 AM Thread Starter
08TRX700XX's Avatar
I was looking at the pics of the two cams and it looks like the 650 has a realy long duration
Two Bro's Slip On
PC3
post #5 of 8 Old 01-16-2009, 10:15 AM
That's what I would be afraid of.
Since the two machines share similar motors but different chassis I would be leery of it. In my mind it's like a truck cam for a SBC and a "corvette" cam for a SBC. Sure they share the same parts but the two engines are serving different purposes. (yes I understand that the XR650 head and block are essentially the same but you get my point...one has to haul a LOT more weight.)
post #6 of 8 Old 01-16-2009, 10:30 AM
The 650 cam pictured is a Stage I Hot Cam so that why it looks bigger because it is. Lobe lift on the XX cam is .255/.259 and the lobe lift of the stage I is .307/.307
Smo0oth is gonna have a 11:1 CP, this stage I cam and my XXR ported head so we will see when he dynoes it, he said hes gonna have a stocker dynoed to compare the two on the same dyno.
Bo White
205-886-7043
post #7 of 8 Old 01-16-2009, 10:32 AM
Its also kinda like the YFZ guys, the YZF cam specs and the YFZ cam specs are basicly the same just the exhaust cam timing. The YFZ guys change the timing on that cam to the YZF spec and gain cheap power.
Bo White
205-886-7043
post #8 of 8 Old 01-16-2009, 10:46 AM
There should'nt be any and critical negative effects since both motors operate in the same RPM range and is only larger by a few cubes. If the XX only had a longer stroke or only a larger bore making the cube difference this could cause some problems. I believe the XX cam will just be a tweaked XR cam to benifit use of the FI
