Adjusting valves..... - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 09-14-2010, 07:17 PM Thread Starter
Its time to adjust the valves on my XX, I got around 1200kms on it now....anyways is it a very complicated task to do ? What are the special tools required to do it and how long does it take for a guy that has never done it ?
Just wondering if I can do it myself or if its too complicated, I've clean carbs, PV did all the maintenance on my machines, snowmobile and atv but never did a valve adjustment ...I'd like to do this myself instead of going to the dealership.
NavyNut is offline
post #2 of 15 Old 09-15-2010, 07:15 AM
It is pretty easy if you got the service manual. As the other threads say, the hardest part is taking off the plastics and the fueltank. Before you start, make sure you have the proper size FEELER GUAGES, and the proper size ALLEN wrench for the left side crank cover (mine got stripped b/c someone didn't have the right size). It is pretty easy, and the manual shows you exactly what to do. Just be sure you do it in a clean spot where no dirt can really get into it. What I usually do is after I get the plastics removed, I wash it up and use an air compressor to blow dry it.
post #3 of 15 Old 09-15-2010, 07:29 PM Thread Starter
Ok, I'll check the manual and all and will go check for feeler guages and see if I got a proper Allen wrench but I should.
For the feeler guages, are they all the same or should I buy a specific one ??
NavyNut is offline
post #4 of 15 Old 09-15-2010, 07:54 PM
USMC0861's Avatar
any set will do, there are metric and std. tolerances listed....its very easy...hardest part is getting to them...dont pay for it
USMC0861 is offline
post #5 of 15 Old 09-16-2010, 06:39 AM
NOT ANY SET WILL DO. Look in the manual and it will give you the tolerances, I can't remember them off the top of my head, but some feeler guages that you can get don't go down small enough for the tolerances you need. If you don't have ones that small, SEARS would be a good place to get them as when I got my first set, they had a gazillion different ones there, and to make it easier, if you had a set that were angled on the one end, that would make life easier getting in there.
post #6 of 15 Old 09-16-2010, 06:03 PM Thread Starter
Give me the model of your feeler gauge so I'll check to see what it looks like. Whats the size I'm looking for the gap of my XX ?
NavyNut is offline
post #7 of 15 Old 09-16-2010, 06:14 PM
boost addict's Avatar
intake.006 exhaust.008
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #8 of 15 Old 09-18-2010, 11:08 AM Thread Starter
How the hell do I remove the tank heat shield, plastic piece to get to the valves, I've removed everything but this part is not explained in the manual.....
NavyNut is offline
post #9 of 15 Old 09-18-2010, 02:16 PM Thread Starter
All done, I figured it out, wiiiii, now I can do the valves on my atv without having to rely on the dealer and if I get a 450 in the future or anything that requires regular valves maintenance I'll be able to do it.
I just hope I tightened everything the way I was supposed to. That heat protector on top of the engine is probably the toughest part to remove, its quite a puzzle when you don't have instructions but I figured it out.
Valves were a bit on the tight side.
How I removed the heat protector......
1. remove the two side plastics with the 700xx engraved in them, just remove the two bolts and the small plastic insert and it will come out.
2. remove the spark plug cap, that one is a bitch, very small area to put your hand in.
3. remove all tubings that goes on top of it.
4. unplug those two connectors thats on end of plug coil(I guess) its on the back of the heat protector, you will see the two connections with small wires. There some type of plastic semi-cover that goes on it just lift it up a little or remove if you want.
5. remove the heat protector, you have to twist it to your throttle side from the back.
What a pain to figured this one out lol.
NavyNut is offline
post #10 of 15 Old 09-21-2010, 03:31 AM
Good job. That coil is actually your starter. This machine is very simple to do. If you are going to dig into 450's, you may want to be a tad more careful as some actually have shims that you'll need to replace.
