front sprocket - Club700XX - Honda TRX700XX Forum
post #1 of 23 Old 09-20-2010, 08:29 PM Thread Starter
eclipsegs0's Avatar
front sprocket
so the stock is a 14.. if i went up one to a 15 would stock chain b ok? i went with a 15 on my rappy 350 but needed a longer chain..
08 trx700xx
ehs programmer
eclipsegs0 is offline
post #2 of 23 Old 09-20-2010, 08:32 PM
There isn't alot of clearance for a bigger sprocket on the XX. I'm not even sure it's possible? I am curious to know if it will even work?
post #3 of 23 Old 09-20-2010, 08:34 PM
RaVxX's Avatar
Yes it works, I'm running a 15 right now, have to take the case saver off thou, thinking of going to a 16 if i put 20s in the back next.
RaVxX is offline
post #4 of 23 Old 09-20-2010, 08:40 PM
ok gotta take off that piece with the 2 bolts? Case saver as you call it?
post #5 of 23 Old 09-20-2010, 09:04 PM Thread Starter
eclipsegs0's Avatar
n r u still running the stock chain with ur 15t
08 trx700xx
ehs programmer
post #6 of 23 Old 09-20-2010, 10:27 PM
RaVxX's Avatar
Yes the thing with the 2 bolts is the case saver and yes it works with stock chain.
I was running the 13 for a while, it was ok i guess, but seen a dude with a 700r that smoked me and my friends 700xx's and he had a 15 on, so i figured I would give it a go, and never looked back, to me it woke the bike up, I know I'm hitting somewhere in the 80s with it.
RaVxX is offline
post #7 of 23 Old 09-21-2010, 06:23 AM Thread Starter
eclipsegs0's Avatar
thanks man
08 trx700xx
ehs programmer
post #8 of 23 Old 09-21-2010, 03:08 PM
WILDMANNUM1's Avatar
The case saver will still fit with a 15 tooth sprocket but has to be removed for the install and held in place while remounting
WILDMANNUM1 is offline
post #9 of 23 Old 09-22-2010, 07:35 PM
dfesmire99's Avatar
Go down in size on the rear sprocket is the same as going up on the front sprocket....don't ride w/o that case saver unless you got a pocket full of money for new cases. If that chain breaks, you're in deep $hit!
dfesmire99 is offline
post #10 of 23 Old 09-23-2010, 01:13 PM Thread Starter
eclipsegs0's Avatar
yea i didnt think about that mayb that way is a lil safer lol
08 trx700xx
ehs programmer
