13t top speed - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 09-21-2010, 08:06 PM Thread Starter
Cranedaddy's Avatar
13t top speed
What is the top speed of the XX with the 13t sprocket on? I tried searching for it but couldn't get any answers, also how bad does it kill first gear?
Cranedaddy is offline
post #2 of 10 Old 09-21-2010, 08:17 PM
Everything else stock?
Depends where you ride on the first gear. For me it still serves a purpose in the tight stuff, but I will take off in second on flat ground.
post #3 of 10 Old 09-21-2010, 08:40 PM Thread Starter
Cranedaddy's Avatar
Yes bone stock. I have absolutely no friends with a sport quad, they all have big utility quads so about 75% of my riding is on fairly tight or rough trails. IF i stick around with them on the trails 1st gear is just a little bit to slow (or I have to keep the rpms up to high) where second is way to fast (bogged down). I DO NOT want to loose very much top speed just for when we do get to the open dirt road and I wanna go
Edit: even on the rougher stuff I haven't had any problems with first gear being to high, only the other quad in front of me being to slow lol
Stock 08 TRX700XX
post #4 of 10 Old 09-21-2010, 08:56 PM
Sounds like the 13T would make second gear work better for you. The best part is it is a cheap try if you don't like it. As far as top speed goes, I don't think any of your ute buddies will pass you. I never checked mine stock with the 13T, but I would figure 77-79mph on top.
Has anybody done a series of GPS runs stock with the 13T?
post #5 of 10 Old 09-21-2010, 08:58 PM
There isn't much difference in the top end btwn the 2, if you can even really get there.
post #6 of 10 Old 09-21-2010, 09:03 PM Thread Starter
Cranedaddy's Avatar
Well thanks for the input. If I don't like it at least its a easy fix and cheap!
Stock 08 TRX700XX
post #7 of 10 Old 09-21-2010, 09:34 PM
id say 80mph
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #8 of 10 Old 09-22-2010, 10:03 AM
My trailtech vapor tells me 80 and if i'm lucky 81 down hill with the 13t.
JTREB is offline
post #9 of 10 Old 09-22-2010, 05:33 PM
speed
mine goes 72+ with a 12 sprocket.Rest of quad is stock. Gps data.
katfish52 is offline
post #10 of 10 Old 09-22-2010, 06:15 PM
mrtheandrew's Avatar
had mine up to about 67 on the gps, and it definitely had some room left before i ran out of logging road.
mrtheandrew is offline
