12T Front Sprocket Install ? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 09-23-2010, 05:16 PM Thread Starter
Duramax's Avatar
Received the 12T I ordered and have a a question. Can you adjust the slack out of the chain or will I have to take a link out? The factory one does not have a master link. Thanks
'08 TRX 700xx
'01 Raptor 660- Sold.
Duramax is offline
post #2 of 6 Old 09-23-2010, 05:25 PM
Qaz
you can adjust the tension out no need to remove any links i installed mine 2 weeks ago
Qaz is offline
post #3 of 6 Old 09-23-2010, 05:38 PM
You can adjust the chain.
post #4 of 6 Old 09-23-2010, 07:56 PM
You can adjust... It's real easy, just read it over on your manual...
post #5 of 6 Old 09-23-2010, 08:05 PM Thread Starter
Duramax's Avatar
Thanks. I wa hoping it could be adjusted without taking out a link. It is a pain in the patootie to put in a master link on one where you can get to it, but I think it would be a real bear to do it on this center chain with the swing arms and boots in the way. I have a press but I use on the Raptor but it must not be a very good one because it is hard to press the o-rings and get the clip back on. Thanks again.
'08 TRX 700xx
Duramax is offline
post #6 of 6 Old 09-23-2010, 08:11 PM
adjusting the chain on this thing is super easy! Thats HONDA engineering at it's best.
