if i went with a 13 tooth sprocket - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 09-27-2010, 10:42 PM Thread Starter
08hondatrx700xx's Avatar
im looking into getting a 13 tooth sprocket. is it hard to install? do i have to buy another chain? if so what size? will it also make a difference if i have 20'' tires on the rear? thanks for your help
08hondatrx700xx is offline
post #2 of 12 Old 09-27-2010, 10:48 PM
nope, nope, and n/a... real easy... there is a "how-to" thread here... check it out!
post #3 of 12 Old 09-27-2010, 10:52 PM Thread Starter
cool thanks
post #4 of 12 Old 09-27-2010, 11:08 PM
Xstriker's Avatar
super easy, however I have a full exhaust and programmer installed and I think I'm going to go back to a 14t sprocket so make sure to keep the old one in case you don't like or want to change it back out.
08 TRX 700XX
HMF Full Performance Exhaust
EHS Programmer
11/16 L8ton Swaybar
Skat~Trak Haulers 20X10X10
Alba Pro Elite Nerfs
Trail Tech Vapor Speedo/odom
Xstriker is offline
post #5 of 12 Old 09-28-2010, 07:44 AM Thread Starter
ok. will do that
post #6 of 12 Old 09-28-2010, 08:03 AM
I have a 13 tooth but I am using the 14 tooth right now. It's easy to switch them out. If I know I'm gonna be riding really tight technical stuff then I'll throw on the 13t if I'm gonna be running faster trails I use the 14t.
I'm not sure how the bike will run with 20" rears? I know there are guys on here with that combo that'll chime in and help.
post #7 of 12 Old 09-28-2010, 08:26 AM Thread Starter
thanks. hopefully they will see this thread. lol
post #8 of 12 Old 09-28-2010, 09:17 AM
boost addict's Avatar
I run 20" rears and tried the 13 tooth for one day. The power band was way to short for me and caused constant switching of gears. The 700xx in stock form is not a high revving engine and the power drops off after 6500 rpm. Just my .02$
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #9 of 12 Old 09-28-2010, 10:48 AM
I tend to agree. Using the 13t WITH 20" tire will make your gearing way too low.... through all your gears. I have the big 3 from EHS and 13t, but 22" Razr tires and that combo seems to be just about perfect for where I ride. Northern California has lots of places where you're on tight technical stuff one moment and wide open fire roads the next. My setup allows me to have low enough gearing for the tight stuff and still give me plenty of speed for the fire road sections.
post #10 of 12 Old 09-28-2010, 02:50 PM
tomkat's Avatar
i use a 13t at the sand dunes in oregon and at capital forest in washington, as mentioned for tight tech trails its perfect and for the hill drags at the dunes its again perfect. i am runnin the fmf 4.1 full system, uni filter and pc3 with a map from bo and adjusted by i think dave in florida, but not sure and havent seem him on here in forever...
i also still use my 14t for more open trails and logging roads, i also switch back and forth between maps for the pc3 depending on which gear i have on and where im riding.
tomkat is offline
