13t and Sand - Club700XX - Honda TRX700XX Forum
post #1 of 29 Old 09-28-2010, 07:23 PM Thread Starter
Rith's Avatar
13t and Sand
Tried looking at other threads but didn't see quite what I was looking for
I have a 13t sprocket coming in soon I plan to combine with the stock 22" dirt tires for technical trail riding
For sand though I have 20" tires. Which gear would you recommend for dunes/sand riding? Should I stick with the 13t (and ignore first gear) or go back to the 14t when doing sand?
Rith is offline
post #2 of 29 Old 09-28-2010, 08:31 PM
tomkat's Avatar
I would say that the 13t with 20's in sand is not gonna work well... I run a 13t in sand but with 22's and I love it.
PM Scuzz cause I believe he has some experience with 20's and a 13t in the sand and I'm pretty sure he said it was terrible and he was digging ditches everywhere in the sand. So my guess is ur gonna want the 14t with 20's in the sand... Get some 22's for the sand then put that 13t on and u will be in the same heaven I'm in. But the 14t with 20's will prolly be sweet as well...
tomkat is offline
post #3 of 29 Old 09-28-2010, 09:10 PM
08hondatrx700xx's Avatar
i have the stock 14 tooth with 20" razr 2s on the rear. i love it. more accelaration and more traction. ive never tired paddle tires...hope this helps
08hondatrx700xx is offline
post #4 of 29 Old 09-28-2010, 10:40 PM
tomkat's Avatar
paddle tires make a huge difference in sand... but like i mentioned before, imho the 14t with 20" paddles should be ok... check with scuzz tho because i am pretty sure he has some experience with 20" paddles and im pretty sure he was ditch digging everywhere and stepped up to 22" paddles...
tomkat is offline
post #5 of 29 Old 09-29-2010, 11:00 AM
I have a 13t and use 22" Razrs for trails and just change to 22" Sand Stars mounted on ITP C5 rims for the dunes. Tires are 22x11x12 and rims are 12x7. The 12" C5 rims clear the mud scraper so you don't even need to remove it. You end up with the same 22" diameter and the same gearing you already had.
Links below...
http://www.itptires.com/images/sandstar12_lg.jpg
http://www.itptires.com/cseries.html
post #6 of 29 Old 09-29-2010, 11:09 AM Thread Starter
Rith's Avatar
The sandstars are very similiar to the tire I already have, but I was saying I already bought 20" ones (so not going back on that now) and was wondering what sprocket (13/14) to go with
I've never ridden in sand before either. I'll stick with the stock one then, was just wondering how the 13t did (with 20" sand paddles)
Rith is offline
post #7 of 29 Old 09-29-2010, 11:56 AM
What kind of paddles do you have for the sand? How well do they hook up? Since they are 20's I'd prolly stick with the 14 tooth depending on your motor setup. With the 14 tooth, big 3 and some paddles that hooked I bogged on some climbs where I had to play with the throttle.
13 tooth and 20's seemed WAY too low for me, but the paddles I had were total shit so that may have been part of the problem.
post #8 of 29 Old 09-29-2010, 12:14 PM Thread Starter
Rith's Avatar
My bikes stock so far. The paddles are an offbrand (can't remember the name >.<) I got a good deal on, and look almost identical to the ITP Sand Star tires except they don't have that tiny little wing in front of the larger paddle
Rith is offline
post #9 of 29 Old 09-29-2010, 12:31 PM
Prolly Sand Sharks.
If you plan on going with the 13 tooth anyway, I would just put that on and just know that if you drag race you'll be launching in second.
You'll notice the biggest change with the 13 on dirt with the dirt tires, and since this will probably be where you do most of your riding I'd just put the 13 on and forget about it.
post #10 of 29 Old 09-29-2010, 02:11 PM
buddy has STOCK TREX 700 14 tooth and skat trak extremes 20" 8 paddle and he had good luck this past week end but I didnt ride it so not sure how good it really was since he wouldnt race me and it was his first time in the sand
Captamer71 is offline
